Didn't even start printing anything yet, just setting bed and nozzle temp, takes for a split second and then gives the error, " Printer reset detected
It looks like your printer reset while a connection was active. If this was intentional you may safely ignore this message. Otherwise you should investigate why your printer reset itself, since this will interrupt prints and also file transfers to your printer's SD."
Rebooted everything, updated Octoprint and all plugins
Yes
No, same problem comes up.
serial.log (12.3 KB)
octoprint.log (261.7 KB)
Octoprint Version 1.9.3
Ender 3V2
Running the plu-in to fix the known temp issue in the Creality firmware
