Printer SD Support - USB missing
My Prusa MK4 does nozt have a SD Card Slot anymore, a USB Stick is mounted now.
Can I upload to USB instead of SD in Octoprint?
(Only SD-Support is given in Settings, would be great, if USB would also be there - because of Power Panic Function inside the Prusa MK4)
Every Plugin and Menu- Entry testet . . . nothing found yet . . .
no -
does not help
octoprint-systeminfo-20230719154347.zip (152.4 KB)
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 1.0.0
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2023-01-30T21:20:04Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: False
octoprint.version: 1.9.2
printer.firmware: Prusa-Firmware-Buddy 4.7.1 (Github)
systeminfo.generated: 2023-07-19T13:43:47Z
systeminfo.generator: zipapi
Standard Paspi 3B - MK4 via USB-C
I'm afraid not. This is an issue with the new firmware of the MK4. When the SD card is gone on the MK4 and USB stick is not provided as substitute, there is nothing OctoPrint can do.
If there are/will be new Prusa Gcodes for the USB stick maybe a plugin can handle this.
But it appears there are none.
Thank you so much for your quick response - ok, I can stop investigating the Stuff for today :wink:
More than nothing. MK4 is fresh from the scratch, so lets see, what Time will bring.
If you got regular issues with power outages, it might be wise to invest in a small UPS :slight_smile:
