Firstly... THANK YOU kindly for the help What is the problem?
When i upload a file from my gcode folde on my windows PC to Octoprint (i drag is into the "Upload to SD" portion of the screen), The printer automatically wants to start printing. The progress bar starts to show progress, even thought the printer is not up to temperature. The bed will move forward, it sounds like it goes past it's limit and the head will move to the rear right. I have to press cancel as quickly as possible to stop the movement of the printer
I've tried to re-slice the item.
Started Octoprint in Safe mode
Tried to disconnect, but then i cannot load the file of course
OctoPrint 1.4.0 running on OctoPi 0.17.0
Pi 3B V1.2
I'm having the same issue. Uploads to printer's SD start and then printer immediately starts doing moves. It's as if Octoprint is streaming the gcode rather than saving it to the SD card.
And saving to SD card literally is streaming the gcode to the printer, just with a single command before that tells the printer it should be saving what comes next instead of executing it. Something about that doesn't seem to work as it should so I need a serial.log to see what's happening.
Did anyone have a solution for this? I am pretty new to this and just set up my Prusa MK3S. I have the same issue. I want the print to load to the SD card, but not try to print right away.
So this issue is 100% reproduceable. I just loaded to SD and cancelled and then refreshed the page and grabbed the logs. So it should show pretty easily where it happened.serial.log (148 Bytes) octoprint.log (1.6 MB)
We can't look into this unless someone affected by this finally shares an enabled serial.log from a reproduction. We are not omniscient, we can't read minds.
