My Prusa i3 MK3 (FW 3.9.3) run by OctoPrint (1.5.3) on OctoPi (0.16.0) has go a stange behaviour when printing ABS (from Prusa).
While printing a "one color only" object with a rather large footprint (8cm x 13 cm), the printer suddenly stops when printing the first layer of the infill (Gyroid, 50%) and asks for a filament change although there's no filament change command (M600) in the gcode (must believe me, code is too big to upload
This is behaviour is reproducible.
When I read the Terminal output I see strange "Recv lines" including M600 stuff (remember: not from the gcode!):
--------------------8<--------------------
Send: N17395 G1 X129.007 Y157.988 E0.00818109
Recv: ok
Send: N17396 G1 X129.023 Y158.257 E0.00702106
Recv: ok
Send: N17397 G1 X129.157 Y158.526 E0.0078397
Recv: fsensor_stop_and_save_print
Recv: fsensor_oq_meassure_start
Recv: fsensor_oq_meassure_stop, 2 samples
Recv: st_sum=700 yd_sum=72 er_sum=0 er_max=0
Recv: yd_min=49178 yd_max=26 yd_avg=36 sh_avg=17
Recv: fsensor_restore_print_and_continue
Recv: Resend: 17396
Recv: ok
Recv: ok
Recv: fsensor_update - M600
Send: N17397 G1 X129.157 Y158.526 E0.00783*97
Recv: echo:Enqueing to the front: "M600"
Recv: echo:busy: processing
Recv: echo:busy: paused for user
What is going on here?
- printing from OctoPrint and from SD-card: same problem
- changing filament: PLA works fine (but i need ABS...)
- changing infill pattern: Rectlinear works fine (standard Gyroid pattern doesn't)
no
don't know
OctoPrint 1.5.3, OctoPi 0.16.0, Prusa i3 MK3, firmware 3.9.3, Firefox 84.0.2, Windows 10 20H2
