Just installed Octoprint on my Surface Pro which is running Win 10 Pro, 64 bit. Created the virtual environment, launchd Octoprint with the "Octoprint serve" command.
I then went through the connection process in Ultimaker Cura, say the option for "Desktop-93...tcp.local'' and clicked "Open in Browser."
However, I cant seem to get the printer to connect and CMD is displaying that " Failed to connect: Port COM4 is busy or does not exist."
Already tried launch a reboot, launching it in safe mode and changing the serial port to "Auto."
System info:
2023-01-07 13:23:40,933 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2023-01-07 13:23:42,157 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:23:42,161 - octoprint.server.api - INFO - Actively logging in user Decter8425 from ::1
2023-01-07 13:23:42,373 - octoprint.server.util.flask - INFO - Passively logging in user Decter8425 from ::1
2023-01-07 13:23:42,373 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:23:42,739 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2023-01-07 13:23:44,524 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2023-01-07 13:23:44,567 - octoprint.server.util.flask - INFO - Passively logging in user Decter8425 from ::1
2023-01-07 13:23:44,567 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:23:45,893 - octoprint.server.util.sockjs - INFO - User Decter8425 logged in on the socket from client ::1
2023-01-07 13:23:54,168 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-01-07 13:23:54,172 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: COM4@115200, COM4@250000, COM4@230400, COM4@57600, COM4@38400, COM4@19200, COM4@9600
2023-01-07 13:23:54,172 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 115200
2023-01-07 13:23:54,172 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 115200
2023-01-07 13:23:54,180 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:23:54,180 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 115200, skipping
2023-01-07 13:23:54,180 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 250000
2023-01-07 13:23:54,180 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 250000
2023-01-07 13:23:54,180 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 250000, skipping
2023-01-07 13:23:54,180 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 230400
2023-01-07 13:23:54,189 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 230400
2023-01-07 13:23:54,190 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:23:54,191 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 230400, skipping
2023-01-07 13:23:54,191 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 57600
2023-01-07 13:23:54,192 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 57600
2023-01-07 13:23:54,194 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:23:54,195 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 57600, skipping
2023-01-07 13:23:54,195 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 38400
2023-01-07 13:23:54,196 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 38400
2023-01-07 13:23:54,199 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:23:54,199 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 38400, skipping
2023-01-07 13:23:54,200 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 19200
2023-01-07 13:23:54,201 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 19200
2023-01-07 13:23:54,202 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:23:54,202 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 19200, skipping
2023-01-07 13:23:54,203 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 9600
2023-01-07 13:23:54,204 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 9600
2023-01-07 13:23:54,205 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:23:54,206 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 9600, skipping
2023-01-07 13:23:54,206 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error"
2023-01-07 13:23:54,207 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2023-01-07 13:23:54,218 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2023-01-07 13:24:37,646 - octoprint.server.util.flask - INFO - Passively logging in user Decter8425 from 192.168.86.86
2023-01-07 13:24:37,646 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:24:43,767 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.86.86
2023-01-07 13:24:47,673 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:24:47,674 - octoprint.server.api - INFO - Actively logging in user Decter8425 from 192.168.86.86
2023-01-07 13:24:47,869 - octoprint.server.util.flask - INFO - Passively logging in user Decter8425 from 192.168.86.86
2023-01-07 13:24:47,871 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:24:48,247 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.86.86
2023-01-07 13:24:49,354 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2023-01-07 13:24:50,241 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.86.86
2023-01-07 13:24:50,293 - octoprint.server.util.flask - INFO - Passively logging in user Decter8425 from 192.168.86.86
2023-01-07 13:24:50,293 - octoprint.access.users - INFO - Logged in user: Decter8425
2023-01-07 13:24:51,954 - octoprint.server.util.sockjs - INFO - User Decter8425 logged in on the socket from client 192.168.86.86
2023-01-07 13:24:59,828 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-01-07 13:24:59,836 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: COM4@115200, COM4@250000, COM4@230400, COM4@57600, COM4@38400, COM4@19200, COM4@9600
2023-01-07 13:24:59,836 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 115200
2023-01-07 13:24:59,836 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 115200
2023-01-07 13:24:59,844 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,844 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 115200, skipping
2023-01-07 13:24:59,852 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 250000
2023-01-07 13:24:59,854 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 250000
2023-01-07 13:24:59,856 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,857 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 250000, skipping
2023-01-07 13:24:59,857 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 230400
2023-01-07 13:24:59,857 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 230400
2023-01-07 13:24:59,858 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,858 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 230400, skipping
2023-01-07 13:24:59,858 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 57600
2023-01-07 13:24:59,859 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 57600
2023-01-07 13:24:59,860 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,861 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 57600, skipping
2023-01-07 13:24:59,861 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 38400
2023-01-07 13:24:59,862 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 38400
2023-01-07 13:24:59,864 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,865 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 38400, skipping
2023-01-07 13:24:59,865 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 19200
2023-01-07 13:24:59,866 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 19200
2023-01-07 13:24:59,868 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,868 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 19200, skipping
2023-01-07 13:24:59,868 - octoprint.util.comm - INFO - Serial detection: Trying port COM4, baudrate 9600
2023-01-07 13:24:59,871 - octoprint.util.comm - INFO - Connecting to port COM4, baudrate 9600
2023-01-07 13:24:59,874 - octoprint.util.comm - INFO - Failed to connect: Port COM4 is busy or does not exist
2023-01-07 13:24:59,874 - octoprint.util.comm - INFO - Serial detection: Could not open port COM4, baudrate 9600, skipping
2023-01-07 13:24:59,874 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error"
2023-01-07 13:24:59,876 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2023-01-07 13:24:59,892 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
Setup:
Printer: CR10V3
Firmware: 5.2.1 (Cura)
Version: 3.10.5
OS: Win 10 Pro, 64 bit.
Browser: Crhome
Any help would be greatly appreciated!!
