Installed a ezboard into CR-10S confirmed everything was functional via control box. Attached pre-existing octopi setup to usb. powered pi and went to webpage. Page came up no serial connection. tried several different settings and boot patterns. nothing. Re-flashed sd with latest and greatest. nothing. installed plugins etc nothing. lost count of how many reboots i have done. Tried different usb cables. Moved pi further away from printer. added ferrite bead to usb cable. tried it on each end.
syslog1.log (234.6 KB)
octoprint.log (131.7 KB) plugin_pluginmanager_console.log (49.2 KB)
plugin_softwareupdate_console.log (13.5 KB)
serial.log (752 Bytes)
pi 3b
octoprint 1.4
octopi 0.17
pi cam 8 months old no idea ver do know its is a newer one
Cr-10s w/ ezboard w/ TH3D unified 2.0 ezabl pro
chrome
windows 10
Hi
disconnect your printer, connect it again, enter dmesg | tail -n 20 and post the output here.
I just want to see what happens when the new connection is established.
Be sure that the printer is turned on.
pi@octopi:~ dmesg | tail -n 20
[ 12.977927] brcmfmac: power management disabled
[ 13.802928] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.803114] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.731224] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.593050] Bluetooth: Core ver 2.22
[ 16.593114] NET: Registered protocol family 31
[ 16.593117] Bluetooth: HCI device and connection manager initialized
[ 16.593132] Bluetooth: HCI socket layer initialized
[ 16.593140] Bluetooth: L2CAP socket layer initialized
[ 16.593163] Bluetooth: SCO socket layer initialized
[ 17.309789] Bluetooth: HCI UART driver ver 2.3
[ 17.309799] Bluetooth: HCI UART protocol H4 registered
[ 17.309853] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 17.309980] Bluetooth: HCI UART protocol Broadcom registered
[ 22.721142] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.721157] Bluetooth: BNEP filters: protocol multicast
[ 22.721180] Bluetooth: BNEP socket layer initialized
[ 23.183268] EXT4-fs (mmcblk0p2): resized to 3145728 blocks
[ 34.962811] EXT4-fs (mmcblk0p2): resized to 5767168 blocks
[ 43.896388] EXT4-fs (mmcblk0p2): resized filesystem to 7725184
pi@octopi:~ pi@octopi:~ $ dmesg | tail -n 20
-bash: pi@octopi:~: command not found
mhmm no connection at all.
Does your printer work with your pc with a something like pronterface?
nope tried direct connecting to pc and no detection
Well then my guess is that you got either a bend pin inside of the connector of your printers maindboard or something is wrong with your printers firmware.
Both should be fixable.
Worst case would be something like a broken ftdi chip. That would also be fixable but it depends on your skill level.
