After I cancel a print, when I try to reprint the file by clicking the print icon again, an important part of my gcode is skipped -> the line that I print outside my print area to ensure filament is flowing smoothly. I know the gcode is there. It worked the first time before I canceled, and I can see it when I click the edit button.
However, if I try to print the same file again, it skips that part and usually the print fails again because the filament is not flowing smoothly - a very frustrating cycle -> failed print leads to failed print leads to failed print!
Maybe this is the expected behavior (to experienced users), but to a newbie, I don't understand why a "cancel" wouldn't cause the next print to start from the very beginning. Is octoprint looking for a specific gcode to start from? Could it be my after cancel gcode (below:)?
G91; Set to Relative position
G1 E-1 F300; retract the filament a bit before lifting the nozzle
G0 Z250; move z axis
G28 X Y; home X axis
M106 S0 ; Turn off fan
M18; Disable all stepper motors
M84; Stop idle hold
M85 S300; if incative for 5 min, shutdown
I'm relatively new to Octoprint. I tried searching the forums and came across the "Log position on cancel" option. I unchecked that but no change in behavior.
Logs
2020-01-24 19:49:46,365 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-01-24 19:49:48,507 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-01-24 19:50:31,462 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2020-01-24 19:53:44,625 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=PrintCancelling
2020-01-24 19:53:44,625 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-01-24 19:53:44,632 - octoprint.util.comm - INFO - Force-sending M108 to the printer
2020-01-24 19:53:44,644 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: mirror_holder.gcode, owner: piOctoPrint, user: piOctoPrint
2020-01-24 19:53:44,647 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=PrintCancelled
2020-01-24 19:53:44,747 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=PrintFailed
2020-01-24 19:54:41,998 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2020-01-24 19:55:01,863 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-01-24 19:55:01,873 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: mirror_holder.gcode, owner: piOctoPrint, user: piOctoPrint
2020-01-24 19:55:01,882 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-01-24 19:55:01,897 - octoprint.events - INFO - Executing a system command
2020-01-24 19:55:01,905 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-01-24 19:55:01,907 - octoprint.plugins.excluderegion - INFO - Printing started
2020-01-24 19:57:06,007 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-01-24 19:57:06,015 - octoprint.util.comm - INFO - Force-sending M108 to the printer
Octoprint 1.3.12, Marlin 1.1.x bugfix branch, Ender 5
