Printing in The Air - AKA Mysterious Z axis Move
New to Octoprint but I have been 3D printing a number of years on a Flashforge Dreamer using an SD card to transfer the gcode between computer and printer.
Printing in the air after a mysterious z axis move that is not in the gcode (cgode below)
  • Connected the printer and sent over some gcode created by the Flashforge slicer.
  • Printer homes
  • warms up
  • Z axis moves 50mm off the bed
  • XY move to the min (Front left of the printer)
  • Moves to the XY start position
  • Moves z to 0.2mm
  • Then moves z axis to about 10mm above the bed
  • starts to extrude and move
Thing is the move to z axis to 10mm above the bed is not in the gcode - so where is it coming from?
Thanks for your help
Ian
Ran the Gcode line by line using the terminal and it does not do the move z axis to 10mm above the bed - so I am assuming that this command is coming from a setting in Octoprint but I can't find it.
Yes - and it will not find the serial port in safemode, so didn't get far
octoprint-systeminfo-20230531102052.zip (136.6 KB)
Using a Raspberry Pi 4,
Octoprint 1.9.0 (Stable) & Flashforge Plugin 0.2.6 (warning on not being actively managed)
PC: Windows 11
Browser: Chrome
Gcode below
rated by ffslicer 2.2.2 05/30/23 08:05:45
;machine_type: Dreamer
;right_extruder_material: PLA
;right_extruder_material_density: 1.24
;filament_diameter0: 1.75
;right_extruder_temperature: 200
;layer_height: 0.18
;perimeter_shells: 2
;top_solid_layers: 3
;bottom_solid_layers: 3
;fill_density: 15%
;fill_pattern: hexagon
;base_print_speed: 60
;travel_speed: 80
;platform_temperature: 50
;right_extruder_temperature_raft0: 0
;right_extruder_temperature_reset:
;left_extruder_temperature_reset:
;start gcode
M118 X91.00 Y41.50 Z37.60 T0
M140 S50 T0
M104 S200 T0
M104 S0 T1
M107
G90
G28
M132 X Y Z A B
G1 Z50.000 F420
G161 X Y F3300
M7 T0
M6 T0
M651 S255
M907 X100 Y100 Z40 A80 B20
;layer_count: 208
M108 T0
G1 X-54.85 Y41.50 F4800
;preExtrude:0.20
G1 Z.200 F420
;structure:pre-extrude
G1 X-83.34 Y41.50 E4.1315 F1200
G1 X-85.10 Y41.26 E4.3890
G1 X-87.04 Y40.46 E4.6934
G1 X-88.70 Y39.17 E4.9982
Hello @Iangwm !
Can you please share the whole gcode as a zip-file?
Also this:
This is a a grbl/Teacup/Yaskawa only command.
This is a Teacup/Yaskawa only command.
This a RepRap only command.
This is very wrongly used. 100 Amps for the X and Y motor?
What is going on there?
For the Gcode commands see here:
https://reprap.org/wiki/G-code
BTW. Always set a 0 (zero) in front of a decimal point. Things are way more obvious then.
SplendorTrayMay23.zip (1.1 MB)
G Code attached
Gcode is generated by Flashforge FlashPrint 5 software and works fine on the Dreamer, if transferred to the printer via SD card.
:eyes: wow
There should be a section: Start gcode. Check that.
For Flashforge printers are using MakerBot firmware (AFAIK), the Gcodes I mentioned before make really no sense.
M7 is for CNC use.
https://reprap.org/wiki/G-code#M7:_Mist_Coolant_On_.28CNC_specific.29
M907 sets the motor currents:
https://reprap.org/wiki/G-code#M907:_Set_digital_trimpot_motor
Sorry there is nothing in the Start Gcode section.
Also wouldn't that run before the Flashprint generated code? not part way through it?
Ian
