I am looking for a way to print 8 assembles one at a time. The issue is they are only 4 mm or smaller in height. The best I can do is to spread 4 nuts to multiple corners as the slice complains there is no room. There is a greyed out safety area but it does not really apply as the assemblies are very short.
And if I manually lay it out the slice then complains they have over lapping safety zones
Cura Ver 5,2,1
Ender 3
My question is simply is there away to remove the check area so I can manually lay it out and then slice it without it checking the safety area or to reduce the area
