**Anytime i send a print using octoprint, it extrudes filament and says
"replace filament"
"send M108 to heat nozzle **
removed most of the plugins used.
Printing through SD Card works fine so something is causing this to happen from within the octoprint file. Nothing was added to gcode in octoprint.
