And it would make sense to enable Serial.log -ging and, with logging enabled, reproduce the issue so the log captures the communication between OctoPrint and the printer. After that been done obtain and upload the systeminfo bundle, thanks in advance
Hi everybody,
I have an update/addition:
Today I printed from SD-Card but with octoprint connected before the print was started. Again it was way more agressive in acceleration and there where massive layer shifts.
you have to turn on the serial log in settings -> serial connection -> common and scroll all the way down and check the box. then sart a new print attempt. When you dont enable serial.log the serial.log file is empty
These are speed and acceleration controles. it should have sth to do with these lines. When you don't set them for a specific reason i would delete them in your gcode file and restart the printer. But i'm not so familiar with these commands. maybe there is someone who can interprete these commands better.
here a small update:
yesterday and this morning I made two prints via octoprint without an issue.
Today another bigger print with again hard accelerations, layer shifts and hot steppers. I measured the stepper temperature with an IR probe. X-stepper was 84°C, y-stepper around 70°C with a room temperature of below 15°C.
The only difference between the prints I can imagine was the running Timelaps at the horse and maybe a different order powering on the Pi and the printer.
Same printer, same firmware, same slicersettings
Hi again,
I started the same print with the horse an hour ago:
I used the file on the Pi from yesterday
first powered up the printer, after that the Pi
restartet Pi in safe mode and timelaps disabled
Print looks fine and steppers are around 30°C.
When the print is finished in several hours I will only change one parameter and not so many at the same time ...
Welcome
Hi.
I had same issue. Octolapse (0.4.1) with setting soft(MP4) was the problem. Head was moved not smooth but with jumps. I printed several times and finaly after disambling Octolapse everything is OK. Resource monitor showing CPU usage between 5 an 8%. Maybe the problem is mane writes on SD?
Yellow thing is printed with octolapse - its spliting apart. The same file without octolapse is OK.
Prusa i3mk3s
Tom
For the past days the printer is running around 10h each day, without timelaps (neither octolaps or any other timelaps) and without problems.
I should probably reinstall everything without octolaps and try again.
The only issue I have quite often:
The Pi loses Wifi-Connection - sometimes when the screensaver from the computer started, sometimes in between, sometimes not. Most of the time after some minutes and reloading the page in the browser it works again. With Octopod on the iPhone it is the same ...
