Camera: Logitech QuickCam Orbit AF
Problem:
The webcam through OctoPrint works perfectly in a different area of my house.
When I plug in my Pi where I need it by my printer the webcam light does not illuminate and Octoprint cannot access the webcam stream or snapshot. Sometimes the webcam light illuminates for about a second before turning off and never turns on again until Pi is rebooted and the cycle repeats.
Note: I have my 5v pin taped and the issue persists even when my printer is not plugged into the Pi (as long as the Pi is in the area).
I believe it is an interference issue but am not sure how to debug it or find the source. My webcam is plugged in via USB so I am confused as to why interference seems to be occurring.
Tried multiple outlets to no avail. Am using the same power supply as when it works.
SystemInfo Bundle:
octoprint-systeminfo-20230625180930.zip (120.3 KB)
Webcamd.log:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 960x720
raspi options: -fps 10
Explicitly set USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
Camera model 046d:0994 is known to not work with -f parameter, stripping it out
<13>Jun 25 09:43:58 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 960x720 -d /dev/video0
MJPG Streamer Version.: 2.0
i: Desired Resolution: 960 x 720
i: Frames Per Second.: -1
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Done bringing up all configured video devices
i: select() timeout
i: cleaning up resources allocated by input thread
Goodbye...
Pi 4B
OctoPi 1.0.0
OctoPrint 1.9.0
Any and all help is appreciated.
