I made a successful print yesterday of an ZYX calibration cube and set my axis calibrations accordingly this morning. I then tried to do some flow calibrations, and now I am receiving G92 errors and I don't know why. It seems to do the first 4 points just fine (5x5 grid), but the 5th it won't go down far enough to trigger the sensor, and thus throws the error. This has never happened to me. Terminal output below. Anyone else have this happen?
Recv: Error:Probing Failed
Send: N33 M108*26
Send: N34 M876 S0*94
Recv: M876 Responding PROMPT_GCODE_INFO
Recv: echo:busy: processing
Recv: X:240.00 Y:48.00 Z:5.00 E:-5.00 Count X:19038 Y:3847 Z:398
Recv: //action:probe_failed
Recv: //action:cancel
Cancelling on request of the printer...
Send: N35 M108*28
Recv: Error:Printer halted. kill() called!
Changing monitoring state from "Cancelling" to "Error: Printer halted. kill() called!"
Send: M112
Send: N36 M112*20
Send: N37 M104 T0 S0*21
Send: N38 M140 S0*94
Changing monitoring state from "Error: Printer halted. kill() called!" to "Offline (Error: Printer halted. kill() called!)"
M503 output below:
Recv: FIRMWARE_NAME:Marlin 2.0_DW5 TM3D SSMDBB SOURCE_CODE_URL:https://github.com/InsanityAutomation/Marlin/tree/CrealityDwin_2.0 PROTOCOL_VERSION:1.0 MACHINE_TYPE:TM3D CR10V2 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:1
Recv: Cap:PROMPT_SUPPORT:1
Recv: Cap:AUTOREPORT_SD_STATUS:1
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: ok P15 B3
Send: M155 S2
Recv: ok P15 B3
Send: M876 P1
Recv: ok P15 B3
Recv: ok P15 B3
