Printing from SD" to "Error: Probing failed"
Changing monitoring state from "Error: Probing failed" to "Offline (Error: Probing failed)"
Printing stops
Restart
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
OctoPrint 1.3.11, Octp PI .15.1, Ender 3 Pro, EZABL, EZ board Marlin 2.0 32 bit board, Windows 10
I have a similar issue when using OP 1.3.11 with a Taz 6. The first auto probe will fail and the printer and the console will show
Changing monitoring state from "Printing" to "Error: Probing failed"Changing monitoring state from "Error: Probing failed" to "Offline (Error: Probing failed)"Connection closed, closing down monitor
But the printer will make a second attempt and succeed. I seem to remember in the past octoprint would not close the connection after the first failure. Is this a setting I can change?
Sounds like you have a G29 command in more than one place. Check your OctoPrint -> Settings -> Gcode -> Before printing script, your slicer's add-ons which might also throw stuff like this and finally, the gcode as produced.
