I have been unable to connect to my new wifi router (TP-Link AC1750 running with WPA2 encryption), despite being able to connect to multiple WPA/WPA2 networks in the past. It seems like the raspi 2 (with well-tested usb wifi dongle) is attempting to connect, then disconnects for "reason=0". I found some threads online stating that this could be due to the network running with WPA/WPA2 encryption instead of WPA2 encryption, so I changed it to WPA2 encryption only. This did not solve the problem. I am certain that the essid and passkey are correct in wpa_network_supplicant.txt, where my other networks are registered, and octopi-network.txt is all commented out.
- Changed network settings in router from WPA to WPA2
- Made sure all quotation marks in octopi network supplicant were edited in vim so that I wouldn't get strange issues with smart quotations from TextEdit
- Commented out all networks in network supplicant file except for the target network
- Tried adding additional characteristics to the network blocks (encryption type etc)
- OctoPrint version : 1.3.8
- OctoPi version : 0.14.0
Log file output of interest. Note connection to router MAC address (50:c7:bf:de:3a:8a) followed by disconnection. This section of the log file is followed by attempts to connect to the other networks listed in the wpa config file, which are not in range.
Jun 14 10:49:22 octopi wpa_supplicant[492]: wlan0: Associated with 50:c7:bf:de:3a:8a
Jun 14 10:49:22 octopi kernel: [2970825.660165] CPU: 0 PID: 17942 Comm: kworker/u2:2 Not tainted 4.9.28+ #998
Jun 14 10:49:22 octopi kernel: [2970825.660179] Hardware name: BCM2835
Jun 14 10:49:22 octopi kernel: [2970825.661105] Workqueue: cfg80211 cfg80211_event_work [cfg80211]
Jun 14 10:49:22 octopi kernel: [2970825.661274] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
Jun 14 10:49:22 octopi kernel: [2970825.661315] [<c0013c90>] (show_stack) from [<c03192f8>] (dump_stack+0x20/0x28)
Jun 14 10:49:22 octopi kernel: [2970825.661387] [<c03192f8>] (dump_stack) from [<c0021c98>] (__warn+0xe4/0x10c)
Jun 14 10:49:22 octopi kernel: [2970825.661410] [<c0021c98>] (__warn) from [<c0021d8c>] (warn_slowpath_null+0x30/0x38)
Jun 14 10:49:22 octopi kernel: [2970825.662330] [<c0021d8c>] (warn_slowpath_null) from [<bf2007f0>] (__cfg80211_connect_result+0x2b4/0x3e0 [cfg80211])
Jun 14 10:49:22 octopi kernel: [2970825.664200] [<bf2007f0>] (__cfg80211_connect_result [cfg80211]) from [<bf1da694>] (cfg80211_process_wdev_events+0x180/0x210 [cfg80211])
Jun 14 10:49:22 octopi kernel: [2970825.666167] [<bf1da694>] (cfg80211_process_wdev_events [cfg80211]) from [<bf1da760>] (cfg80211_process_rdev_events+0x3c/0x70 [cfg80211])
Jun 14 10:49:22 octopi kernel: [2970825.667896] [<bf1da760>] (cfg80211_process_rdev_events [cfg80211]) from [<bf1d5208>] (cfg80211_event_work+0x24/0x2c [cfg80211])
Jun 14 10:49:22 octopi kernel: [2970825.668977] [<bf1d5208>] (cfg80211_event_work [cfg80211]) from [<c00389e8>] (process_one_work+0x11c/0x398)
Jun 14 10:49:22 octopi kernel: [2970825.669129] [<c00389e8>] (process_one_work) from [<c0038ca0>] (worker_thread+0x3c/0x508)
Jun 14 10:49:22 octopi wpa_supplicant[492]: wlan0: CTRL-EVENT-CONNECTED - Connection to 50:c7:bf:de:3a:8a completed [id=0 id_str=]
Jun 14 10:49:22 octopi kernel: [2970825.669162] [<c0038ca0>] (worker_thread) from [<c003e820>] (kthread+0xf8/0x114)
Jun 14 10:49:22 octopi kernel: [2970825.669205] [<c003e820>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
Jun 14 10:49:22 octopi kernel: [2970825.669253] ---[ end trace 6cc71d6259396a3e ]---
Jun 14 10:49:22 octopi wpa_supplicant[492]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jun 14 10:49:22 octopi wpa_supplicant[492]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=US
Jun 14 10:49:23 octopi avahi-daemon[402]: Withdrawing address record for 128.12.6.137 on wlan0.
Jun 14 10:49:23 octopi avahi-daemon[402]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 128.12.6.137.
Jun 14 10:49:23 octopi avahi-daemon[402]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jun 14 10:49:23 octopi dhcpcd[691]: wlan0: deleting route to 128.12.6.128/26
Jun 14 10:49:23 octopi dhcpcd[691]: wlan0: deleting default route via 128.12.6.129
Jun 14 10:49:23 octopi dhcpcd[691]: wlan0: carrier acquired
Jun 14 10:49:23 octopi dhcpcd[691]: wlan0: IAID 06:2b:8a:90
Jun 14 10:49:24 octopi dhcpcd[691]: wlan0: soliciting an IPv6 router
Jun 14 10:49:24 octopi dhcpcd[691]: wlan0: rebinding lease of 128.12.6.137
Jun 14 10:49:25 octopi ntpd[720]: Deleting interface #227 wlan0, 128.12.6.137#123, interface stats: received=64, sent=64, dropped=0, active_time=9410 secs
Jun 14 10:49:25 octopi ntpd[720]: 178.124.134.106 interface 128.12.6.137 -> (none)
Jun 14 10:49:25 octopi ntpd[720]: 213.186.36.183 interface 128.12.6.137 -> (none)
Jun 14 10:49:25 octopi ntpd[720]: 2.248.181.59 interface 128.12.6.137 -> (none)
Jun 14 10:49:25 octopi ntpd[720]: 149.210.142.45 interface 128.12.6.137 -> (none)
Jun 14 10:49:25 octopi ntpd[720]: peers refreshed
Jun 14 10:49:29 octopi dhcpcd[691]: wlan0: probing for an IPv4LL address
Jun 14 10:49:29 octopi dhcpcd[691]: wlan0: DHCP lease expired
Jun 14 10:49:29 octopi dhcpcd[691]: wlan0: soliciting a DHCP lease
Jun 14 10:49:34 octopi dhcpcd[691]: wlan0: using IPv4LL address 169.254.198.94
Jun 14 10:49:34 octopi dhcpcd[691]: wlan0: adding route to 169.254.0.0/16
Jun 14 10:49:34 octopi avahi-daemon[402]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.198.94.
Jun 14 10:49:34 octopi avahi-daemon[402]: New relevant interface wlan0.IPv4 for mDNS.
Jun 14 10:49:34 octopi avahi-daemon[402]: Registering new address record for 169.254.198.94 on wlan0.IPv4.
Jun 14 10:49:35 octopi ntpd[720]: Listen normally on 228 wlan0 169.254.198.94 UDP 123
Jun 14 10:49:35 octopi ntpd[720]: peers refreshed
Jun 14 10:49:36 octopi dhcpcd[691]: wlan0: no IPv6 Routers available
Jun 14 10:51:04 octopi wpa_supplicant[492]: wlan0: CTRL-EVENT-DISCONNECTED bssid=50:c7:bf:de:3a:8a reason=0
Jun 14 10:51:04 octopi dhcpcd[691]: wlan0: carrier lost
Jun 14 10:51:04 octopi wpa_supplicant[492]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jun 14 10:51:04 octopi wpa_supplicant[492]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=US
Jun 14 10:51:05 octopi avahi-daemon[402]: Withdrawing address record for 169.254.198.94 on wlan0.
Jun 14 10:51:05 octopi avahi-daemon[402]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.198.94.
Jun 14 10:51:05 octopi avahi-daemon[402]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jun 14 10:51:05 octopi dhcpcd[691]: wlan0: deleting route to 169.254.0.0/16
Octopi WPA Supplicant (network of interest is "Smart Bidet Wifi")
country=US
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
# This is only used to configure multiple wifi networks or other advanced wifi features.
# take a look into octopi-network.txt instead if you only need basic wifi configuration
# 'man -s 5 wpa_supplicant.conf' for advanced options
#network={
# ssid="Your Wifi SSID"
# psk="supersecretwifipassword"
## You can configure more than 1 wifi networks by adding more 'network' blocks
#network={
network={
ssid="Smart Bidet Wifi"
psk="XXXXX"
network={
ssid="Stanford Residences"
key_mgmt=NONE
network={
ssid="AdventurousRouter"
psk="XXXXX"
