I Have a problem when sending a file from Cura to Octoprint since i have installed the 1.7.1 release, i got the error
Octoprint error
{"error":The requested URL was not found on the server. If you ent(ered the URL Manually please check your spelling and try again."}
I try the URL with the OCTOPRINT button in Cura it work (and the file is stored in octoprint's files butthe print don't start automaticly. I Check the API wich is good
Yes
Yes, but when i reload Octoprint in normal mode the problem is back
Octoprint version 1.7.1, Windows 11, printers: Artillery Genius, Geeetech A10, Flsun Q5
