I can't start the server because some plugins are causing problems on startup.
When starting the server I get a WARNING message:
WARNING - Plugin "OctoPi Support Plugin" did not pass check
There are other problems I can see in the logs, but that is the one that seems most troublesome.
I also find this line at the end to be very weird:
Listening on http://[::]:5000
I'm following the instructions from this link.
Reinstalled multiple times on freshly flashed Raspbian.
Hardware: RASPBERRY PI 3 MODEL B+
Firmware: Raspbian GNU/Linux 9.4 (stretch)
OctoPrint version: 1.3.9
debug log from starting the server:
2018-08-29 14:31:39,445 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-08-29 14:31:39,448 - octoprint.startup - INFO - ******************************************************************************
2018-08-29 14:31:41,122 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-08-29 14:31:41,124 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for discovery from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/discovery/__init__.py
2018-08-29 14:31:41,519 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for announcements from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements/__init__.py
2018-08-29 14:31:42,881 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for logging from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging/__init__.py
2018-08-29 14:31:42,911 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for corewizard from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/corewizard/__init__.py
2018-08-29 14:31:42,931 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for softwareupdate from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py
2018-08-29 14:31:43,130 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for printer_safety_check from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check/__init__.py
2018-08-29 14:31:43,152 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for octopi_support from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/octopi_support/__init__.py
2018-08-29 14:31:43,170 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-08-29 14:31:43,173 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for cura from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/cura/__init__.py
2018-08-29 14:31:43,240 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for virtual_printer from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/virtual_printer/__init__.py
2018-08-29 14:31:43,248 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for pluginmanager from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py
2018-08-29 14:31:43,400 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for action_command_prompt from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt/__init__.py
2018-08-29 14:31:44,505 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-08-29 14:31:44,506 - octoprint.plugin.core - DEBUG - Loaded plugin discovery: Discovery
2018-08-29 14:31:44,649 - octoprint.plugin.core - DEBUG - Loaded plugin announcements: Announcement Plugin
2018-08-29 14:31:44,652 - octoprint.plugin.core - DEBUG - Loaded plugin logging: Logging
2018-08-29 14:31:44,654 - octoprint.plugin.core - DEBUG - Loaded plugin corewizard: Core Wizard
2018-08-29 14:31:44,657 - octoprint.plugin.core - DEBUG - Loaded plugin softwareupdate: Software Update
2018-08-29 14:31:44,660 - octoprint.plugin.core - DEBUG - Loaded plugin printer_safety_check: Printer Safety Check
2018-08-29 14:31:44,663 - octoprint.plugin.core - DEBUG - Loaded plugin cura: CuraEngine (<= 15.04)
2018-08-29 14:31:44,665 - octoprint.plugin.core - DEBUG - Loaded plugin virtual_printer: Virtual Printer
2018-08-29 14:31:44,669 - octoprint.plugin.core - DEBUG - Loaded plugin pluginmanager: Plugin Manager
2018-08-29 14:31:44,670 - octoprint.plugin.core - DEBUG - Loaded plugin action_command_prompt: Action Command Prompt Support
2018-08-29 14:31:44,671 - octoprint.plugin.core - DEBUG - Enabled plugin discovery: Discovery
2018-08-29 14:31:44,673 - octoprint.plugin.core - DEBUG - Enabled plugin announcements: Announcement Plugin
2018-08-29 14:31:44,674 - octoprint.plugin.core - DEBUG - Enabled plugin logging: Logging
2018-08-29 14:31:44,676 - octoprint.plugin.core - DEBUG - Enabled plugin corewizard: Core Wizard
2018-08-29 14:31:44,681 - octoprint.plugin.core - DEBUG - Enabled plugin softwareupdate: Software Update
2018-08-29 14:31:44,685 - octoprint.plugin.core - DEBUG - Enabled plugin printer_safety_check: Printer Safety Check
2018-08-29 14:31:44,689 - octoprint.plugin.core - DEBUG - Enabled plugin cura: CuraEngine (<= 15.04)
2018-08-29 14:31:44,701 - octoprint.plugin.core - DEBUG - Enabled plugin virtual_printer: Virtual Printer
2018-08-29 14:31:44,707 - octoprint.plugin.core - DEBUG - Enabled plugin pluginmanager: Plugin Manager
2018-08-29 14:31:44,711 - octoprint.plugin.core - DEBUG - Enabled plugin action_command_prompt: Action Command Prompt Support
2018-08-29 14:31:44,714 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-08-29 14:31:44,943 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-08-29 14:31:45,001 - octoprint.server - DEBUG - Starting intermediary server on http://[::]:5000
2018-08-29 14:31:45,005 - octoprint.server - INFO - Intermediary server started
2018-08-29 14:31:45,007 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-08-29 14:31:45,013 - octoprint.plugin.core - DEBUG - Parsing plugin metadata for octopi_support from AST of /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/octopi_support/__init__.py
2018-08-29 14:31:45,030 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-08-29 14:31:46,274 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-08-29 14:31:46,362 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-08-29 14:31:46,365 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-08-29 14:31:46,370 - octoprint.events - DEBUG - Subscribed listener <function on_settings_update at 0x739ec370> for event SettingsUpdated
2018-08-29 14:31:46,379 - octoprint.events - DEBUG - Subscribed listener <bound method Printer._on_event_MetadataAnalysisFinished of <octoprint.printer.standard.Printer object at 0x739ea030>> for event MetadataAnalysisFinished
2018-08-29 14:31:46,380 - octoprint.events - DEBUG - Subscribed listener <bound method Printer._on_event_MetadataStatisticsUpdated of <octoprint.printer.standard.Printer object at 0x739ea030>> for event MetadataStatisticsUpdated
2018-08-29 14:31:46,387 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin logging
2018-08-29 14:31:46,393 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin virtual_printer
2018-08-29 14:31:46,399 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin action_command_prompt
2018-08-29 14:31:46,404 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin corewizard
2018-08-29 14:31:46,410 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin printer_safety_check
2018-08-29 14:31:46,466 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-08-29 14:31:46,467 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin softwareupdate
2018-08-29 14:31:46,474 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin cura
2018-08-29 14:31:46,479 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin announcements
2018-08-29 14:31:49,232 - octoprint.util.pip - INFO - Using "/home/pi/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2018-08-29 14:31:52,242 - octoprint.util.pip - INFO - Version of pip is 18.0
2018-08-29 14:31:52,245 - octoprint.util.pip - INFO - pip installs to /home/pi/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-08-29 14:31:52,248 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-08-29 14:31:52,249 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin pluginmanager
2018-08-29 14:31:52,258 - octoprint.plugin.core - DEBUG - Initialized plugin mixin implementation for plugin discovery
2018-08-29 14:31:52,259 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-08-29 14:31:52,273 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements
| Core Wizard (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/corewizard
| CuraEngine (<= 15.04) (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/cura
| Discovery (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/discovery
| Logging (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging
| Plugin Manager (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
| Software Update (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2018-08-29 14:31:52,308 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 972238848
| os:
| platform: linux2
| python:
| pip: '18.0'
| version: 2.7.13
| virtualenv: /home/pi/OctoPrint/venv
2018-08-29 14:31:52,324 - octoprint.server - DEBUG - Deleting /home/pi/.octoprint/generated/webassets...
2018-08-29 14:31:52,327 - octoprint.server - DEBUG - Creating /home/pi/.octoprint/generated/webassets...
2018-08-29 14:31:52,330 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-08-29 14:31:52,332 - octoprint.server - DEBUG - Deleting /home/pi/.octoprint/generated/.webassets-cache...
2018-08-29 14:31:52,335 - octoprint.server - DEBUG - Creating /home/pi/.octoprint/generated/.webassets-cache...
2018-08-29 14:31:52,337 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-08-29 14:31:52,382 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event ALERT
2018-08-29 14:31:52,384 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CAPTURE_DONE
2018-08-29 14:31:52,385 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CAPTURE_FAILED
2018-08-29 14:31:52,386 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CAPTURE_START
2018-08-29 14:31:52,391 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CLIENT_CLOSED
2018-08-29 14:31:52,392 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CLIENT_OPENED
2018-08-29 14:31:52,394 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CONNECTED
2018-08-29 14:31:52,397 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CONNECTING
2018-08-29 14:31:52,399 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CONNECTIVITY_CHANGED
2018-08-29 14:31:52,401 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event CONVEYOR
2018-08-29 14:31:52,403 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event COOLING
2018-08-29 14:31:52,405 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event DISCONNECTED
2018-08-29 14:31:52,407 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event DISCONNECTING
2018-08-29 14:31:52,409 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event DWELL
2018-08-29 14:31:52,412 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event EJECT
2018-08-29 14:31:52,414 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event ERROR
2018-08-29 14:31:52,415 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event E_STOP
2018-08-29 14:31:52,417 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FILE_ADDED
2018-08-29 14:31:52,420 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FILE_DESELECTED
2018-08-29 14:31:52,422 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FILE_REMOVED
2018-08-29 14:31:52,423 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FILE_SELECTED
2018-08-29 14:31:52,425 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FIRMWARE_DATA
2018-08-29 14:31:52,426 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FOLDER_ADDED
2018-08-29 14:31:52,428 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event FOLDER_REMOVED
2018-08-29 14:31:52,430 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event HOME
2018-08-29 14:31:52,431 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event METADATA_ANALYSIS_FINISHED
2018-08-29 14:31:52,432 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event METADATA_ANALYSIS_STARTED
2018-08-29 14:31:52,435 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event METADATA_STATISTICS_UPDATED
2018-08-29 14:31:52,437 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event MOVIE_DONE
2018-08-29 14:31:52,440 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event MOVIE_FAILED
2018-08-29 14:31:52,441 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event MOVIE_RENDERING
2018-08-29 14:31:52,443 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event POSITION_UPDATE
2018-08-29 14:31:52,445 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event POSTROLL_END
2018-08-29 14:31:52,447 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event POSTROLL_START
2018-08-29 14:31:52,449 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event POWER_OFF
2018-08-29 14:31:52,451 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event POWER_ON
2018-08-29 14:31:52,452 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINTER_PROFILE_ADDED
2018-08-29 14:31:52,454 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINTER_PROFILE_DELETED
2018-08-29 14:31:52,457 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINTER_PROFILE_MODIFIED
2018-08-29 14:31:52,459 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINTER_RESET
2018-08-29 14:31:52,461 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINTER_STATE_CHANGED
2018-08-29 14:31:52,463 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_CANCELLED
2018-08-29 14:31:52,465 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_CANCELLING
2018-08-29 14:31:52,467 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_DONE
2018-08-29 14:31:52,469 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_FAILED
2018-08-29 14:31:52,472 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_PAUSED
2018-08-29 14:31:52,474 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_RESUMED
2018-08-29 14:31:52,477 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event PRINT_STARTED
2018-08-29 14:31:52,479 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event REGISTERED_MESSAGE_RECEIVED
2018-08-29 14:31:52,482 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SETTINGS_UPDATED
2018-08-29 14:31:52,484 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SHUTDOWN
2018-08-29 14:31:52,486 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_CANCELLED
2018-08-29 14:31:52,489 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_DONE
2018-08-29 14:31:52,491 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_FAILED
2018-08-29 14:31:52,494 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_PROFILE_ADDED
2018-08-29 14:31:52,496 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_PROFILE_DELETED
2018-08-29 14:31:52,498 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_PROFILE_MODIFIED
2018-08-29 14:31:52,499 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event SLICING_STARTED
2018-08-29 14:31:52,501 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event STARTUP
2018-08-29 14:31:52,505 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event TOOL_CHANGE
2018-08-29 14:31:52,507 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event TRANSFER_DONE
2018-08-29 14:31:52,510 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event TRANSFER_FAILED
2018-08-29 14:31:52,512 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event TRANSFER_STARTED
2018-08-29 14:31:52,514 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event UPDATED_FILES
2018-08-29 14:31:52,516 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event UPLOAD
2018-08-29 14:31:52,518 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event WAITING
2018-08-29 14:31:52,521 - octoprint.events - DEBUG - Subscribed listener <bound method DebugEventListener.eventCallback of <octoprint.events.DebugEventListener object at 0x739eaf10>> for event Z_CHANGE
2018-08-29 14:31:52,739 - octoprint.server - DEBUG - Registered API of plugin announcements under URL prefix /plugin/announcements
2018-08-29 14:31:52,751 - octoprint.server - DEBUG - Registered API of plugin corewizard under URL prefix /plugin/corewizard
2018-08-29 14:31:52,763 - octoprint.server - DEBUG - Registered API of plugin cura under URL prefix /plugin/cura
2018-08-29 14:31:52,775 - octoprint.server - DEBUG - Registered API of plugin discovery under URL prefix /plugin/discovery
2018-08-29 14:31:52,799 - octoprint.server - DEBUG - Registered API of plugin logging under URL prefix /plugin/logging
2018-08-29 14:31:52,814 - octoprint.server - DEBUG - Registered API of plugin pluginmanager under URL prefix /plugin/pluginmanager
2018-08-29 14:31:52,832 - octoprint.server - DEBUG - Registered API of plugin softwareupdate under URL prefix /plugin/softwareupdate
2018-08-29 14:31:52,839 - octoprint.server - DEBUG - Registered assets of plugin action_command_prompt under URL prefix /plugin/action_command_prompt
2018-08-29 14:31:52,847 - octoprint.server - DEBUG - Registered assets of plugin printer_safety_check under URL prefix /plugin/printer_safety_check
2018-08-29 14:31:52,909 - octoprint.server - DEBUG - Adding maximum body size of 52428800B for POST requests to /plugin/pluginmanager/upload_archive)
2018-08-29 14:31:52,910 - octoprint.server - INFO - Shutting down intermediary server...
2018-08-29 14:31:53,141 - octoprint.server - INFO - Intermediary server shut down
2018-08-29 14:31:53,147 - octoprint.events - INFO - Processing startup event, this is our first event
2018-08-29 14:31:53,148 - octoprint.events - DEBUG - Firing event: Startup (Payload: None)
2018-08-29 14:31:53,149 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-08-29 14:31:53,155 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-08-29 14:31:53,163 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-08-29 14:31:53,177 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2018-08-29 14:31:53,199 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on raspberrypi for SSDP
2018-08-29 14:31:53,207 - octoprint.server - INFO - Listening on http://[::]:5000
2018-08-29 14:31:53,284 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-08-29 14:31:53,899 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
