Problem with Filament Sensor Simplified
What is the problem? I installed Filament Sensor Simplified and for quite some time it worked as advertised. Most recently a couple of rolls of filament ago. Today, I ran out of filament and it failed to recognize it.
Went to plugins and did a test per the "Test Button" and it triggered properly. But then I noticed at the top under the "Board mode GPIO/BCM mode"
a notification of " Board mode has been set by third party/other plugin and is disabled " .
Obviously, the plugin won't work if it has been disabled.
Tried searching here and github for a solution
It was noted in the setup image the GPIO is a drop down, but in mine, that is greyed out but still shows the proper setting as noted above.
So I guess I am looking for a way to set this in the plugin????
octoprint-systeminfo-20260307192206.zip (5.1 KB)
Yes, but as expected all plugins are disabled
Upon rebooting back into normal mode, the GPIO dropdown was enabled. Did a test both of triggered and detected and it worked for the test, BUT the aforementioned Notification of being disabled returned!
OctoPrint 1.11.7
Python 3.11.2
OctoPi* 1.1.0 (build 2025.05.13.134411
Ender 5 with SKR 1.4 mainboard Marlin 2.x
