Problem with starting the octoprint service pi3
The problem occured after i updated to octoprint version 0.18.0
When trying to access the gui from browser it displays The OctoPrint server is currently not running message. When i connected with ssh to the pi and run systemctl status octoprint service, i got the following message:
Unit service.service could not be found.
● octoprint.service - The snappy web interface for your 3D printer
   Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2023-03-25 17:18:23 EET; 31s ago
  Process: 2017 ExecStart=/home/pi/oprint/bin/octoprint serve --host=${HOST} --port=${PORT} (code=exited, status=1/FAILURE)
 Main PID: 2017 (code=exited, status=1/FAILURE)
Mar 25 17:18:23 octopi octoprint[2017]:     from octoprint import main
Mar 25 17:18:23 octopi octoprint[2017]:   File "<frozen importlib._bootstrap>", line 983, in _find_and_load
Mar 25 17:18:23 octopi octoprint[2017]:   File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
Mar 25 17:18:23 octopi octoprint[2017]:   File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
Mar 25 17:18:23 octopi octoprint[2017]:   File "<frozen importlib._bootstrap_external>", line 724, in exec_module
Mar 25 17:18:23 octopi octoprint[2017]:   File "<frozen importlib._bootstrap_external>", line 857, in get_code
Mar 25 17:18:23 octopi octoprint[2017]:   File "<frozen importlib._bootstrap_external>", line 525, in _compile_bytecode
Mar 25 17:18:23 octopi octoprint[2017]: ValueError: bad marshal data (unknown type code)
Mar 25 17:18:23 octopi systemd[1]: octoprint.service: Main process exited, code=exited, status=1/FAILURE
Mar 25 17:18:23 octopi systemd[1]: octoprint.service: Failed with result 'exit-code'.
Have tried powercycling the pi and restarting the octoprint service though ssh with systemctl
Yes
Since the service cannot start i cannot generate a systeminfo bundle
pi 3
python 3.7.3
running Raspbian GNU/Linux 10 (buster) on pi
