Hello,
TENLOG TLD3 printer equipment and RAPSBERRY PI 4, Microsoft EDGE
I suggest you analyze the two versions of OCTOPRINT for the following reason.
It is no longer possible to view the speed and flow settings and the fan speed for version 1.10.2 and python 3.9.2. the latest update.
I also noticed that this version pauses printing! (see the temperature display terminal)
Note my firmware is up to date for a TENLOG TLD3 printer.
I can change the speed and flow but in a blind way without an initial display marker of the setting and the value to adjust.
Here is the version where everything works perfectly on the same TLD3 with OCTOPRINT 1.10.2 PYTHON 3.7.3 and Octopi 0.18.0 (built 2022.09.27.151125)
I can view and modify the flow rate, print speed and fan speed values.
Note that it is confusing following updates to find that the settings are not operational, why?
You explain that it is no longer possible to view the values following the limitation of the communication protocol with the firmware??
I find this message confusing because the firmware of the TLD3 is not the cause, so where does the error come from?
I can conclude that I made an adjustment to obtain octopi 0.18.0 and everything works very well... it is a comfort of use.
So the communication protocol is not up to par, that is the observation!
