I'm trying, for the first time, to get an event to fire my python script. Here is what I put in /home/pi/.octiprint/config.yaml:
events:
enabled: True
subscriptions:
- event: PrintStarted
command: python /home/pi/bin/events.py {__filename} {__now}
type: system
enabled: True
It's right after the appearance section in the first 20 or so lines of the file. After I restart Octoprint, I get the following in the logs:
2018-09-23 23:27:28,047 - octoprint.events - INFO - Disabled command trigger: {'enabled': False, 'command': 'python /home/pi/bin/events.py {__filename} {__now}', 'event': 'PrintStarted', 'type': 'system'}
2018-09-23 23:27:28,279 - octoprint.server - INFO - Shutting down intermediary server...
2018-09-23 23:27:28,305 - octoprint.server - INFO - Intermediary server shut down
2018-09-23 23:27:28,309 - octoprint.events - INFO - Processing startup event, this is our first event
2018-09-23 23:27:28,309 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-09-23 23:27:28,315 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-09-23 23:27:28,394 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
and the config.yaml entry has been !changed! to
events:
enabled: true
subscriptions:
- command: python /home/pi/bin/events.py {__filename} {__now}
enabled: false
event: PrintStarted
type: system
My script does not get called on the PrintStarted event.
I have tried different ordering of the lines in the subscription section but that didn't seem to make a difference. I believe that this section of the python code in _initSubscriptions()
if "enabled" in subscription.keys() and not subscription["enabled"]:
self._logger.info("Disabled command trigger: {!r}".format(subscription))
continue
is making the log entry but I don't know if it is triggered after the config.yaml file is doctored to show enabled as false (it starts out true in my entry). I also don't know what code is changing enabled to false and reordering the lines in my subscription entry.
I'm running octoprint 1.39 on a Raspberry Pi 3B+ installed using Octopi. It is connected to an Anet A8 running Marlin 1.1.9.
Is there a way to attach my complete config.yaml file and log file to this entry as attachments?
