webcam is not showing on main screen but it's visible in the setup. when I print the print loops several times at different positions up to 10-20 times until it goes forward
I restarted the Raspi several times
webcam working in setup, but not available in Save mode
Complete Logs
2020-12-06 09:46:04,399 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-06 09:46:23,723 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1875626}
2020-12-06 09:57:39,712 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CCR10S_behalter_v2.SLDPRT.gcode
2020-12-06 09:57:39,717 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=2000 --speed-y=2000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CCR10S_behalter_v2.SLDPRT.gcode
2020-12-06 09:57:41,330 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.5.1...
2020-12-06 09:58:16,972 - octoprint.plugins.softwareupdate - INFO - Update of octoprint to 1.5.1 successful!
2020-12-06 09:58:17,250 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-12-06 09:58:17,254 - octoprint.plugins.softwareupdate - INFO - Restarting...
2020-12-06 09:58:17,426 - octoprint.plugins.tracking - INFO - Sent tracking event update_successful, payload: {'to_version': u'1.5.1', 'from_version': u'1.4.2', 'target': u'octoprint'}
2020-12-06 09:58:17,484 - octoprint.server - INFO - Shutting down...
2020-12-06 09:58:18,113 - octoprint.server - INFO - Calling on_shutdown on plugins
2020-12-06 09:58:18,114 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-12-06 09:58:18,121 - octoprint.events - INFO - Event loop shut down
2020-12-06 09:58:18,466 - octoprint.plugins.tracking - INFO - Sent tracking event shutdown, payload: {}
2020-12-06 09:58:18,519 - octoprint.server - INFO - Goodbye!
2020-12-06 09:58:21,330 - octoprint.startup - INFO - ******************************************************************************
2020-12-06 09:58:21,333 - octoprint.startup - INFO - Starting OctoPrint 1.5.1
2020-12-06 09:58:21,333 - octoprint.startup - INFO - ******************************************************************************
2020-12-06 09:58:22,028 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-12-06 09:58:22,103 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-12-06 09:58:22,104 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-12-06 09:58:22,106 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-12-06 09:58:22,146 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-12-06 09:58:23,944 - octoprint.plugin.core - INFO - Found 24 plugin(s) providing 24 mixin implementations, 42 hook handlers
2020-12-06 09:58:24,123 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-12-06 09:58:24,151 - octoprint.server - INFO - Intermediary server started
2020-12-06 09:58:24,191 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-12-06 09:58:24,676 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-12-06 09:58:24,682 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-12-06 09:58:24,683 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-12-06 09:58:24,686 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-12-06 09:58:24,688 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-12-06 09:58:24,690 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-12-06 09:58:24,692 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-12-06 09:58:24,694 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-12-06 09:58:24,697 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-12-06 09:58:24,699 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-12-06 09:58:24,701 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-12-06 09:58:24,703 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-06 09:58:24,705 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-06 09:58:24,708 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-12-06 09:58:24,709 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-12-06 09:58:24,711 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2020-12-06 09:58:24,825 - octoprint.plugins.filamentreload - INFO - Running RPi.GPIO version '0.7.0'
2020-12-06 09:58:25,054 - octoprint.plugins.softwareupdate - INFO - Version cache was created for another version of OctoPrint, not using it
2020-12-06 09:58:26,268 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-12-06 09:58:27,427 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-12-06 09:58:27,429 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-06 09:58:27,431 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-06 09:58:27,440 - octoprint.plugin.core - INFO - Initialized 24 plugin implementation(s)
2020-12-06 09:58:27,684 - octoprint.plugin.core - INFO - 24 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Action Commands (0.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_actioncommands
| EEPROM Marlin Editor Plugin (1.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eeprom_marlin
| Filament Sensor Reloaded (1.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentreload
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| FileManager (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Slicer (1.4.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_slicer
| System Command Editor (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_systemcommandeditor
| Webcam Tab (0.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_webcamtab
2020-12-06 09:58:27,729 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
OctoPi
OctoPi Version 0.17.0, running on Raspberry Pi 3 Model B Rev 1.2
OctoPrint Version 1.5.1
