Hi experts!
I'm using Octoprint since I've got my new Ender 3 printer. Before that I was working with Repetier Server so I'm quite new to Octoprint.
I've found the example scripts on docs.octoprint.org. I copied the scripts of Listing 6 (afterPrintPaused) and Listing 7 (beforePrintResumed) to my octoprint.
Listing 6 seems to work fine:
{% if pause_position.x is not none %}
; relative XYZE
G91
M83
; retract filament, move Z slightly upwards
G1 Z+5 E-5 F4500
; absolute XYZE
M82
G90
; move to a safe rest position, adjust as necessary
G1 X0 Y0
{% endif %}
but with Listing 7 I have a problem:
; relative extruder
M83
; prime nozzle
G1 E-5 F4500
G1 E5 F4500
G1 E5 F4500
; absolute E
M82
; absolute XYZ
G90
; reset E
G92 E{{ pause_position.e }}
; move back to pause position XYZ
G1 X{{ pause_position.x }} Y{{ pause_position.y }} Z{{ pause_position.z }} F4500
; reset to feed rate before pause if available
{% if pause_position.f is not none %}G1 F{{ pause_position.f }}{% endif %}
{% endif %}
Normally I use this pause to change the filament. When I do this I use the extrude and recect function of octoprint to get the old filemanent out and the new in. E.g. I retract the filament for 400 to 500 mm, until I can get it easily out of the extruder, then I extrude the new filament it maybe for 550 or 600 mm, until all the rest of the old filament is out of the nozzle.
The problem is that the printer remembers all extruder movements. When I'm ready with changing the filament and click on "Continue", the extruder compensates for all these different paths again, so that the filament is pushed back much too far when it starts printing again.
I deactivated the line ;reset E
;G92 E{{ pause_position.e }}
But this has no effect...The filament movement after the restart is still executed.
OctoPrint version 1.4.2; Octopi Version 0.17.0; Ender 3; different browsers
