I have followed through the installation guide for installing octoprint on windows but when I get to the command "octoprint serve" I get the following error.
(venv) c:\Octoprint>octoprint serve
2023-02-09 20:12:36,419 - octoprint.startup - CRITICAL - Could not initialize settings manager: DLL load failed while importing netifaces: %1 is not a valid Win32 application.
2023-02-09 20:12:36,419 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
Uninstalled and reinstalled python 3.10.9
Try opening your command prompt as an administrator. The windows installer (I made) is way easier than the manual install instructions BTW and gives options to setup OctoPrint as a service. You can get it from the releases section of its GitHub repo.
Thanks for the prompt reply. I did try opening the command prompt as administrator but I had the same results.
I had a quick look at the GitHub link and am not sure what to do from there. Do I have to uninstall what I have already done or will the installer overwrite my previous downloads?
I clicked on the latest downloads and there were 3 files, do I just download those and extract the zip file, then run the .exe file?
