Probs to reach Octoprint web (propably haproxy misconfig issue)
ERR_CONNECTION_REFUSED while accessing octoprint.local (http&https and tested on port 80/8080/5000)
curl: (7) Failed to connect to localhost port 443: Verbindungsaufbau abgelehnt
curl: (7) Failed to connect to localhost port 80: Verbindungsaufbau abgelehnt
curl: (7) Failed to connect to localhost port 5000: --> some html output (good)
Logs (syslog, dmesg, ...)
journalctl - xe
Sep 25 20:23:17 octopi haproxy[1429]: [ALERT] 267/202317 (1429) : Fatal errors found in configuration.
Sep 25 20:23:17 octopi systemd[1]: haproxy.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- An ExecStartPre= process belonging to unit haproxy.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Sep 25 20:23:17 octopi systemd[1]: haproxy.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit haproxy.service has entered the 'failed' state with result 'exit-code'.
Sep 25 20:23:17 octopi systemd[1]: Failed to start HAProxy Load Balancer.
-- Subject: A start job for unit haproxy.service has failed
-- A start job for unit haproxy.service has finished with a failure.
-- The job identifier is 879 and the job result is failed.
Sep 25 20:23:17 octopi systemd[1]: haproxy.service: Service RestartSec=100ms expired, scheduling restart.
Sep 25 20:23:17 octopi systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
-- Subject: Automatic restarting of a unit has been scheduled
-- Automatic restarting of the unit haproxy.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Sep 25 20:23:17 octopi systemd[1]: Stopped HAProxy Load Balancer.
-- Subject: A stop job for unit haproxy.service has finished
-- A stop job for unit haproxy.service has finished.
-- The job identifier is 939 and the job result is done.
Sep 25 20:23:17 octopi systemd[1]: haproxy.service: Start request repeated too quickly.
-- The job identifier is 939 and the job result is failed.
HAPROXY.cfg
global
maxconn 4096
user haproxy
group haproxy
daemon
log 127.0.0.1 local1 debug
tune.ssl.default-dh-param 2048
defaults
log global
mode http
option httplog
option dontlognull
retries 3
option redispatch
option http-server-close
option forwardfor
maxconn 2000
timeout connect 5s
timeout client 15min
timeout server 15min
frontend public
bind :::80 v4v6
bind :::443 v4v6 ssl crt /home/pi/ssl/mydomain.com.pem ca-file /home/pi/ssl/OctoPrintCA.crt
scheme https code 301 if !{ ssl_fc }
default_backend octoprint
backend octoprint
acl needs_scheme req.hdr_cnt(X-Scheme) eq 0
    reqrep ^([^\ :]*)\ /(.*) \1\ /\2
    reqadd X-Scheme:\ https if needs_scheme { ssl_fc }
    reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc }
    option forwardfor
    errorfile 503 /etc/haproxy/errors/503-no-octoprint.http
backend webcam
reqrep ^([^\ :])\ /webcam/(.) \1\ /\2
server webcam1 127.0.0.1:8080
global
maxconn 4096
user haproxy
group haproxy
daemon
Startup message in ssh
File "", line 1, in
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/init.py", line 6, in
import logging as log
File "/usr/lib/python2.7/logging/init.py", line 26, in
import sys, os, time, cStringIO, traceback, warnings, weakref, collections
File "/usr/lib/python2.7/weakref.py", line 14, in
from _weakref import (
ImportError: cannot import name _remove_dead_weakref
Access OctoPrint from a web browser on your network by navigating to any of:
http://octopi.local
http://192.168.2.112
http://[fd7d:10dc:6c4:1:ce72:4f62:21bf:e186]
http://[2003:ec:6bdd:1078:fb71:dbe4:e3bf:2f67]
https is also available, with a self-signed certificate.
OctoPrint version : unknown
OctoPi version : 0.16.0
status haproxy.service
pi@octopi:~ $ systemctl status haproxy.service
● haproxy.service - HAProxy Load Balancer
Loaded: loaded (/lib/systemd/system/haproxy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2019-09-25 20:33:59 BST; 16s ago
Docs: man:haproxy(1)
file:/usr/share/doc/haproxy/configuration.txt.gz
Process: 1092 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=1/FAILURE)
Sep 25 20:33:59 octopi systemd[1]: haproxy.service: Service RestartSec=100ms expired, scheduling restart.
Sep 25 20:33:59 octopi systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Sep 25 20:33:59 octopi systemd[1]: Stopped HAProxy Load Balancer.
Sep 25 20:33:59 octopi systemd[1]: haproxy.service: Start request repeated too quickly.
Sep 25 20:33:59 octopi systemd[1]: haproxy.service: Failed with result 'exit-code'.
Sep 25 20:33:59 octopi systemd[1]: Failed to start HAProxy Load Balancer.
Connecting via Chrome from windows to raspi over wlan. Wlan (with ssh) works fine.
The /etc/haproxy/haproxy.cfg file probably needs formatting for it to work correctly. Here's mine:
global
        maxconn 4096
        user haproxy
        group haproxy
defaults
        log     global
        mode    http
        option  httplog
        option  dontlognull
        retries 3
        option redispatch
        option forwardfor
        maxconn 2000
        timeout connect 5s
frontend public
        bind :::80 v4v6
        bind :::443 v4v6 ssl crt /etc/ssl/snakeoil.pem
backend octoprint
        option forwardfor
backend webcam
        reqrep ^([^\ :]*)\ /webcam/(.*)     \1\ /\2
I mved the current cfg. file and replaced it with the backup (which has standard format) - Service restarts also shows the error ...
Active: failed (Result: exit-code) since Thu 2019-09-26 09:49:17 BST; 11s ago
Process: 1353 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=0/SUCCESS)
Process: 1354 ExecStart=/usr/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS (code=exited, status=1/FAILURE)
Main PID: 1354 (code=exited, status=1/FAILURE)
Sep 26 09:49:17 octopi systemd[1]: haproxy.service: Service RestartSec=100ms expired, scheduling restart.
Sep 26 09:49:17 octopi systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Sep 26 09:49:17 octopi systemd[1]: Stopped HAProxy Load Balancer.
Sep 26 09:49:17 octopi systemd[1]: haproxy.service: Start request repeated too quickly.
Sep 26 09:49:17 octopi systemd[1]: haproxy.service: Failed with result 'exit-code'.
Sep 26 09:49:17 octopi systemd[1]: Failed to start HAProxy Load Balancer.
I found a hint in https://discourse.haproxy.org/t/fails-to-start-haproxy/3881 that gives this output. tune.ssl can be changed, so that leaves the bindings as errors..
[WARNING] 268/095228 (1528) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
[ALERT] 268/095228 (1528) : Starting frontend public: cannot bind socket [:::80]
[ALERT] 268/095228 (1528) : Starting frontend public: cannot bind socket [:::443]
sudo haproxy -db -f /etc/haproxy/haproxy.cfg & solved the problem. Octoprint is now running.
But only manually. It seems some rights are missing for the service. But i donΒ΄t know which exactly.
Can someone help me here, pls ?
I'm not really the expert with haproxy, I'm afraid. Anyone, anyone...?
Hi everybody,
I found some new issues reguarding haproxy within Debian GNU/Linux 13 (trixie) that maybe prevent the connection to the Octoprint Web Ui.
I used ssh to connect to my Pi and typed: systemctl status haproxy.service
I got this respond:
Job for haproxy.service failed because the control process exited with error code.
See "systemctl status haproxy.service" and "journalctl -xeu haproxy.service" for details.
pi@OctoPi:~ $ systemctl status haproxy.service
Γ— haproxy.service - HAProxy Load Balancer
     Loaded: loaded (/usr/lib/systemd/system/haproxy.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Tue 2025-10-14 13:50:45 CEST; 21s ago
 Invocation: c20cd725439e4d4b9057c682c1189be5
    Process: 2734 ExecStart=/usr/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS (code=exited, status=1/FAILURE)
   Main PID: 2734 (code=exited, status=1/FAILURE)
Okt 14 13:50:45 OctoPi systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Okt 14 13:50:45 OctoPi systemd[1]: haproxy.service: Start request repeated too quickly.
Okt 14 13:50:45 OctoPi systemd[1]: haproxy.service: Failed with result 'exit-code'.
Okt 14 13:50:45 OctoPi systemd[1]: Failed to start haproxy.service - HAProxy Load Balancer.
After that I typed:
pi@OctoPi:~ $ sudo haproxy -c -f /etc/haproxy/haproxy.cfg
[NOTICE]   (2871) : haproxy version is 3.0.11-1+deb13u1
[NOTICE]   (2871) : path to executable is /usr/sbin/haproxy
[WARNING]  (2871) : config : unexpected character 'i' after the timer value '15min', only (us=microseconds,ms=milliseconds,s=seconds,m=minutes,h=hours,d=days) are supported. This will be reported as an error in next versions.
[ALERT]    (2871) : config : parsing [/etc/haproxy/haproxy.cfg:35] : The 'reqrep' directive is not supported anymore since HAProxy 2.1. Use 'http-request replace-path', 'http-request replace-uri' or 'http-request replace-header' instead.
[ALERT]    (2871) : config : parsing [/etc/haproxy/haproxy.cfg:36] : The 'reqadd' directive is not supported anymore since HAProxy 2.1. Use 'http-request add-header' instead.
[ALERT]    (2871) : config : parsing [/etc/haproxy/haproxy.cfg:37] : The 'reqadd' directive is not supported anymore since HAProxy 2.1. Use 'http-request add-header' instead.
[ALERT]    (2871) : config : parsing [/etc/haproxy/haproxy.cfg:43] : The 'reqrep' directive is not supported anymore since HAProxy 2.1. Use 'http-request replace-path', 'http-request replace-uri' or 'http-request replace-header' instead.
[ALERT]    (2871) : config : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
[ALERT]    (2871) : config : Fatal errors found in configuration.
It is easy to solve the timers by editing the /etc/haproxy/haproxy.cfg and change 15min to 15m but for the other 4 issuses I don't know how these can be solved.
please could anyone help here?
Hi again,
I solved this problem on my own, and yes it prevents the Web UI.
What you have to do is:
Edit the '/etc/haproxy/haproxy.cfg'
In the 'defaults' section change the timers from 15min to 15m
In the 'backend octoprint' section change
reqrep ^([^\ :])\ /(.) \1\ /\2 replace with http-request replace-path ^([^\ :])\ /(.) \1\ /\2
reqadd X-Scheme:\ https if needs_scheme { ssl_fc } replace with http-request add-header X-Scheme https if needs_scheme { ssl_fc }
reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc } replace with http-request add-header X-Scheme http if needs_scheme !{ ssl_fc }
and in the 'backend webcam' section
reqrep ^([^\ :])\ /webcam/(.) \1\ /\2 replace with http-request replace-path /webcam/(.*) /\1
After these changes my Octoprint Web Ui is showing up and works: :slight_smile:
Have Fun
