I cannot connect to my Prusa i3mk3s mmu2s using my setup
Tried safe mode,
Changing timeout
Logs ( octoprint.log , serial.log or output on terminal tab at a minimum , browser error console if UI issue ... no logs, no support! )
Terminal:
Connecting to: /dev/ttyACM0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6ef21570, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0 125
Recv: start
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
serial.log (1.0 KB)
octoprint (1).log (884.9 KB)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possible )
Octoprint version:1.4.0
Octopi version 0.15.0PE
Printer: Prusa i3 mk3s mmu2s
Raspberry pi: 3b+
Connection type: USB
Browser: Chrome, Chromium
OS: Windows, Linux
