I am a mere user with low skills.
What I would like to see is the Prusa IR sensors ( both FINDA and IR) displayed on the Command or Control tabs.
Are these codes even available to you folks?
Thank you in advance, happy coding!
Sadly not:
I suspected as much, as one of you fine code heads would have added it. I am in the same boat Cato is. I had to park my MMU2 until I get the tower on the MK3S sorted.
THANK you for dealing with this so quickly! I greatly appreciate the coding you guys (and ladies) do to make our lives so much better.
BTW, I had done a quick search to see if others were sharing this query, and I did not see the quoted note. My apologies!
