I've connected my Raspberry Pi 3B+ to a Prusa MK3S printer. The connection is via GPIO and the Pi is powered externally through a power supply (not via GPIO from MK3S Einsy board).
I can get a connection at 115200 baud rate, but the serial line has LOTS of noise/garbage on it, rendering the "Operational" status unusable.
I've followed the Prusa and Octoprint forum suggestions for configuring the operating system and Octoprint settings.
Here is the relevant snippet from octoprint.log:
2019-11-24 10:59:35,388 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2019-11-24 10:59:35,396 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2019-11-24 10:59:35,410 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-24 10:59:35,417 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-24 10:59:36,686 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2019-11-24 10:59:36,693 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-24 10:59:36,706 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2019-11-24 10:59:36,714 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2019-11-24 10:59:59,636 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 5, current line = 7
| Last lines in terminal:
| Recv: (n�k{�����BB$%��H�k�L�o���������������������������������gR)�����{n�-�n��jjL{
| Recv: � ���N�O��-h�(J���
| Recv: �*)HL�
| Recv: �L k+����FB�Kjm��5�������n���{Y����i;� ��/��LLO��J��k�K-k)n�we}w�w�����BB!�h��BBJ�)1��DDB!!(
| Recv: k��BJ��#2���O�k�����������������������������-35�zZ��o�k�JL�Il��k�N���I���kI�n��.H����L���BB�!!!!!!������BC��(�J#�k������������������������wH�k�H�u������������������������n��j��.M-���---�m-n�kO��./m�, �����BBBBB#�!!!�H(�����\�!M ����S#������bWW�15���n�2���k�~�ok
���������������������[������!�,���]���n�������������� ����BSB#1�! ���!�H(�#��J��k�Y����������������Z{k9��5�.�k���������������i���9����-���-��*�L J��(�m��j���kk{��(�����@BFB"!��-����%#�
| Recv: ( �k{X��S-�k�e�1��������%g�jnr��5)�����������������V���)���������j�/t��DBBB��N���*��H����!!�(H����B!���B!!IB�Zj�����w�no��nk����com�������o�o��O��,�H��J������MM���jg--]M�No������BD"�����BD!���BBC"%!!���c!���c!����c!���������k�o���������+��kB�b�Zhkq-kk�*�k/(�llH�����k�
| Recv: {� hkhh �
| Recv: h�
| Recv: ����)%���1�����I������{3�ekm���kno������+��:��N��������nk{j+{k{
���N;��YN��J(Q�4Q�
| Recv: �����FBBB!1��
| Recv: ��JJ���J������ck))������Ks�k�m�u{oo�Uokoowo��omm������������������o�now��������'�im�n��o���r����*.��M�ok�kecno:Unknow�����+��KB�!���^�O"(2�G�k������������������}���})I�����N����k�O�����k�k����njkoM��m�O/�"(2)
| Recv: ��H����������������k����kk)�kj�o)V��j�B����]�U]��������.K��+j�
| Recv: "*�)
| Recv: ok
| Recv: ��������own��omo���:�RK����K�n���j-�Hok-���Ml�o)�l.j��DBbBB&!!!!P
| Recv: ���B!�(H� *���c1(�cc)���)�k����K��k�k�n�u{no:���������������M+/jk�j}km���
| Recv: �)B����jJ/�Lno���o� kk�H
| Recv: (k������BBB!a/-H
| Recv: ���a�
�Bki-L�������1���������7kkm�������������bg�������h�sksum,"Lqst Line:!>�
| Recv: Resend�$5KokJ������[_����J��okkkkkkkkk))�KO������n�����M�N�����N��+n�
2019-11-24 10:59:59,686 - octoprint.util.comm - INFO - Firmware didn't send an 'ok' with their resend request. That's a known bug with some firmware variants out there. Simulating an ok to continue...
2019-11-24 10:59:59,692 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 1, current line = 7
| Recv: {� hkhh �
| Recv: h�
���N;��YN��J(Q�4Q�
| Recv: �����FBBB!1��
| Recv: "*�)
| Recv: ok
| Recv: ���a�
| Recv: H��h!!J��B!����BBBB!(H�(Hlk�B�1(��r�-�ok
������������z������������������o����n�,�kj�)�*��-�ok�}��k���s[��][_��������mesksum,0Last Line: 0�
| Recv: Resend:<1
| Send: N5 M105*34
2019-11-24 10:59:59,799 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Offline"
2019-11-24 11:00:00,197 - octoprint.util.comm - INFO - Firmware didn't send an 'ok' with their resend request. That's a known bug with some firmware variants out there. Simulating an ok to continue...
OctoPrint Version 1.3.12
OctoPi Version 0.17.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Prusa firmware version: 3.8.1
