I try to connect via RPI3 and USB Port.
The connection Works fine but one Day, I did no changes on the Settings off the Printer and Octoprint and this Error comes.
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyACM0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0x6b665f30, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=60.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: start
Recv: ;S
Recv: ;S
Recv: ;S
Recv: ;S
Recv: ;S
Recv: SN update failed
Recv: echo: 4.0.2-2528
Recv: echo: Last Updated: Aug 1 2022 16:46:42 | Author: (none, default config)
Recv: Compiled: Aug 1 2022
Recv: echo: Free Memory: 1836 PlannerBufferBytes: 1760
Recv: echo:Stored settings retrieved
Recv: echo:Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E415.00
Recv: echo:UStep resolution:
Recv: echo: M350 X16 Y16 Z16 E16
Recv: echo:Maximum feedrates - normal (mm/s):
Recv: echo: M203 X200.00 Y200.00 Z12.00 E120.00
Recv: echo:Maximum feedrates - stealth (mm/s):
Recv: echo: M203 X100.00 Y100.00 Z12.00 E120.00
Recv: echo:Maximum acceleration - normal (mm/s2):
Recv: echo: M201 X1000 Y1000 Z200 E5000
Recv: echo:Maximum acceleration - stealth (mm/s2):
Recv: echo: M201 X960 Y960 Z200 E5000
Recv: echo:Acceleration: P=print, R=retract, T=travel
Recv: echo: M204 P1250.00 R1250.00 T1250.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B0.00 X10.00 Y10.00 Z0.40 E4.50
Recv: echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P16.13 I1.16 D56.23
Recv: echo:PID heatbed settings:
Recv: echo: M304 P126.13 I4.30 D924.76
Recv: echo:Retract: S=Length (mm) F:Speed (mm/m) Z: ZLift (mm)
Recv: echo: M207 S3.00 F2700.00 Z0.00
Recv: echo:Recover: S=Extra length (mm) F:Speed (mm/m)
Recv: echo: M208 S0.00 F480.00
Recv: echo:Auto-Retract: S=0 to disable, 1 to interpret extrude-only moves as retracts or recoveries
Recv: echo: M209 S0
Recv: echo:Filament settings: Disabled
Recv: adc_init
Recv: Extruder fan type: NOCTUA
Recv: CrashDetect DISABLED
Recv: FSensor ENABLED (sensor board revision: 0.3 or older)
Recv: Sending 0xFF
Recv: echo:SD card ok
Recv: LCD status changed
Recv: // action:dump_available
Recv: MMU2S => MK32S 'V:402'
Recv: MMU2S => MK32S 'BN:380'
Recv: MMU version valid
Recv: MMU - ENABLED
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
I did no changes on the Settings off the Printer and The Octoprint and this Error comes.
RPI Port is off.
Active second Serial Port on Printer.
Reinstall Octopi
Flash the Printer FW new.
Yes
You can download this in
octoprint-systeminfo-20220805084948.zip (27.2 KB)
... no bundle, no support!)
OctoPrint version 1.8.1, OctoPi version 0.18, Prusa MK3S MMU2, TZB FW 4.0.2 compiled by my own, Firefox, Windows 10, ... as much data as possible
