i have a Prusa i3 MK3S (v.3.8.1.2869)+ MMU2s (v.1.0.6) and a OctoPrint (v.1.4.0)/ OctoPi (v.0.15.0PE)
I'm unable to connect printer to Octoprint via RPI port.
Could you please help me ?
It worked without MMU2S module
Tried Safe-mode but doesn't work.
RPI port turned ON on Prusa printer. Turned OFF and ON
Removed SD card
Completely reboot printer.
Serial port : dev/ttyAMAO
Baudrate : 115200
Printer profiles : 5 extruders / Shared Nozzle
Connecting to: /dev/ttyAMA0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0xafb76d10, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
You may make a backup of all the things you installed to OctoPrint and store it to your PC. When OctoPrint is running, you can use the backup file to get the plugins back to your OctoPrint.
When you get your new Pi 4, you can just swap the SD card from the Zero to the 4. Take care to use a goof USB cable and a proper power adaper for the Pi 4 - not a charger.
I reinstall the good OctoPrint version then configure follow the instruction on the link you gave me and it work. The printer connects !!
I have few question, can i update to OctoPrint 1.4.0 without issue ? Currently the version is 1.3.12.
Also you tell me to buy a good USB cable and proper power adapter ? Do you have some link ? I'm new with Raspberry and i don't know exactly what i need to run the Pi 4 on Prusa.
