M112 sent to the printer due to Should resend line 35006 but no sufficient history is available, can't resend. Line to resend is 35006, current line is 15874, line history has 50 entries.
What's particularly awkward is that line '35006' seems to be in the future (current line: 15874).
This happens once every 100-200 hours.
Ideas what can cause it? (I've read "bad usb cable"). Any other ideas? It does not happen frequently.
I changed the setting to ignore the errors, per OctoPrint Settings · Jyers/Marlin Wiki · GitHub -- but that's more a bandaid than solution.
no - the issue is not easily reproducible. happens once every 100 hours or so
n/a
octoprint-systeminfo-20220921023652.zip (484.0 KB)
2022-09-21 01:21:38,329 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: URSA/GB3-input-onepiece_0.15mm_PLA_MK3S_42m--with-pause.gcode, owner: psla, user:
psla
2022-09-21 01:21:38,330 - octoprint.plugins.excluderegion - INFO - File selected, resetting internal state
2022-09-21 01:21:38,340 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2022-09-21 01:21:38,340 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: URSA/GB3-input-onepiece_0.15mm_PLA_MK3S_42m--with-pause.gcode, owner: psla, user:
psla
2022-09-21 01:21:38,364 - octoprint.plugins.PrintJobHistory - INFO - PrintJob 'GB3-input-onepiece_0.15mm_PLA_MK3S_42m--with-pause.gcode' started!
2022-09-21 01:21:38,368 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-09-21 01:21:38,367 - octoprint.plugins.PrintJobHistory - INFO - Try reading Temperature from PreHeat-Plugin...
2022-09-21 01:21:38,370 - octoprint.plugins.PrintJobHistory - WARNING - ... PreHeat Button Plugin not installed/enabled
2022-09-21 01:21:38,371 - octoprint.plugins.excluderegion - INFO - Printing started
2022-09-21 01:21:38,377 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2022-09-21 01:22:38,430 - octoprint.plugins.PrintJobHistory - INFO - Temperature read from Printer Bed: '60.0' Tool tool0: '215.0' after a delay of '60' seconds
2022-09-21 01:31:32,339 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2022-09-21 01:38:06,984 - octoprint.util.comm - WARNING - Should resend line 35006 but no sufficient history is available, can't resend. Line to resend is 35006, current line is 15874, line
2022-09-21 01:38:06,984 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error"
2022-09-21 01:38:06,986 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2022-09-21 01:38:06,999 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error
2022-09-21 01:38:07,014 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2022-09-21 01:38:07,015 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 35006, current line = 15877
| Last lines in terminal:
| Send: N15873 G1 X126.439 Y97.768 E.03766*98
| Recv: T:209.9 /210.0 B:59.9 /60.0 T0:209.9 /210.0 @:64 B@:108 P:0.0 A:39.6
| Recv: echo:busy: processing
| Recv: T:210.1 /210.0 B:59.8 /60.0 T0:210.1 /210.0 @:61 B@:100 P:0.0 A:39.7
| Recv: T:210.0 /210.0 B:59.7 /60.0 T0:210.0 /210.0 @:63 B@:104 P:0.0 A:39.7
| Recv: T:210.4 /210.0 B:59.8 /60.0 T0:210.4 /210.0 @:56 B@:77 P:0.0 A:39.6
| Recv: T:210.5 /210.0 B:59.8 /60.0 T0:210.5 /210.0 @:56 B@:71 P:0.0 A:39.8
| Recv: T:211.2 /210.0 B:60.0 /60.0 T0:211.2 /210.0 @:45 B@:37 P:0.0 A:39.8
| Recv: Resend: 35006
| Send: M112
| Send: N15874 M112*46
| Send: N15875 M104 T0 S0*47
| Send: N15876 M140 S0*104
