almost any print sent with octoprint (1.7.2) results in the same issue of after a bed probe the extruder parks and begins an m600 filament change. It "unloads" then loads a random position on the MMU, then unloads that and loads the proper position and asks if it was loaded correctly. It then re probes the bed and begins printing.
I have tried turning off all 3rd party plig ins, running in safe mode, changed the filament sensor and recalibrated, printing from SD card, and a fresh install of octoprint. Problem does not replicate when printing from SD.
Yes, no improvement.
no
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
octoprint-systeminfo-20220113032532.zip (41.2 KB)
Octoprint 1.7.2, octoprint 18, browser chrome 97. Board Raspberry pi 4b, official power supply, no power issues or throttling. Sheilded usb cable.
Latest prusa firmware of 3.10 and latest MMU firmware, re flashed last week to be sure. Using prusaslicer official build 2.4.
Adding a snippet of the terminal log when this happensProcessing: TerminalLog.txt...
Of course as soon as I enable serial logging it stops acting up.... Leaving it on in case it happens again
Snagged it happening, hopefully its in here somewhere. I'll see if I can replicate it in safe mode tomorrow.
serial (1).log (894.5 KB)
octoprint (1).log (414.1 KB)
octoprint-systeminfo-20220113042007.zip (193.5 KB)
EDIT: got it to do it in safe mode with the very next print, info below
octoprint-systeminfo-20220113043920.zip (185.4 KB)
foosel
February 2, 2022, 10:45am
5
This is an issue with your printer's or the MMU's firmware, not with OctoPrint.
See my analysis here:
opened 12:28AM - 02 Feb 22 UTC
closed 10:42AM - 02 Feb 22 UTC
triage
### The problem
almost any print sent with octoprint (1.7.2) results in the sam⦠e issue of after a bed probe the extruder parks and begins an m600 filament change. It "unloads" then loads a random position on the MMU, then unloads that and loads the proper position and asks if it was loaded correctly. It then re probes the bed and begins printing.
### Did the issue persist even in safe mode?
Yes, it did persist
### If you could not test in safe mode, please state why
_No response_
### Version of OctoPrint
1.7.2
### Operating system running OctoPrint
OctoPi 0.18
### Printer model & used firmware incl. version
MK3s with MMU2S latest versions
### Browser and version of browser, operating system running browser
Chrome, windows 10
### Checklist of files to include below
- [X] Systeminfo Bundle (always include!)
- [ ] Contents of the JavaScript browser console (always include in cases of issues with the user interface)
- [ ] Screenshots and/or videos showing the problem (always include in case of issues with the user interface)
- [ ] GCODE file with which to reproduce (always include in case of issues with GCODE analysis or printing behaviour)
### Additional information & file uploads
[octoprint-systeminfo-20220113043920.zip](https://github.com/OctoPrint/OctoPrint/files/7982770/octoprint-systeminfo-20220113043920.zip)
[serial (1).log](https://github.com/OctoPrint/OctoPrint/files/7982771/serial.1.log)
[octoprint (1).log](https://github.com/OctoPrint/OctoPrint/files/7982772/octoprint.1.log)
please see the issue here https://community.octoprint.org/t/prusa-mk3s-w-mmu-enqueing-to-front-m600/40734/3
system
Closed
May 3, 2022, 10:46am
6
