Prusa Slicer timesout when connecting to Octopi on Raspberry Pi3
My Prusa Slicer recently updated and now it times out nearly every time I try to connect to Octopi.
Verified under Prusa settings that the printer configuration is working. Tested access to Octopi on a local browser and was successful. Successfully connect to the Octopi through the Prusa local printer tab. Played with all the settings in the Octopi UI.
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36 Edg/131.0.0.0
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : false
connectivity.enabled : true
connectivity.online : false
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : false
env.hardware.cores : 4
env.hardware.freq : 1200
env.hardware.ram : 917016576
env.os.bits : 32
env.os.id : linux
env.os.platform : linux2
env.plugins.pi_support.model : Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version : 0.17.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 19.3.1
env.python.version : 2.7.16
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.6.1
printer.firmware : Marlin 1.1.9 (Github)
systeminfo.generator : systemapi
Hello @Eric_Mattison !
Please do so.
Please attach the systeminfo bundle to your next post.
So you tried from a different network?
I didn't try from a different network, same computer, same network, just a different browser. When I opened the UI from Internet Explorer, I am able to do all the functions. Then when I open in the Prusa Slicer, I can also access the UI, it tests fine, but when I try to upload a print, that's when it times out.
I didn't try safe mode, as Octopi appears be functioning just fine. I suspect that the issue is that Prusa Slicer is expecting a faster response than what the Pi is able to generate. This is an issue that has come up in the new update. I know that historically this has happened on occasion, but none of the old responses seem to apply to today.
