Since fresh Octopi flash/install eyecam will not start properly
Lots and lots of various configurations in /boot/OctoPi.txt
I also tried giving it " /dev/v4l/by-id/" (with my gnarly actual USB name "usb-OmniVision_Technologies__Inc._USB_Camera-B4.09.24.1-video-index0")
as shown in this very helpful post with it still not working
Starting up webcamDaemon...
/boot/octopi.txt: line 24: -r 640x480 -f 5 -y: command not found
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Jan 23 16:38:16 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
i: Could not obtain the requested pixelformat: MJPG , driver gave us: GRBG
... will try to handle this by checking against supported formats.
i: init_VideoIn failed
Whatever is available from website for today, literally flashed SD card an hour ago.
Version 1.7.3
Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Relevent info
pi@octopi:~ $ ls /dev/v4l/by-path
platform-3f980000.usb-usb-0:1.3:1.0-video-index0 platform-bcm2835-isp-video-index0 platform-bcm2835-isp-video-index2
platform-bcm2835-codec-video-index0 platform-bcm2835-isp-video-index1 platform-bcm2835-isp-video-index3
/boot/octopi.txt: line 24: -r 640x480 -f 5 -y -d /dev/v4l/by-path/platform-3f980000.usb-usb-0:1.3:1.0-video-index0: No such file or directory
camera: usb
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
<13>Jan 23 17:06:58 root: Starting USB webcam
### Additional options to supply to MJPG Streamer for the USB camera
# See https://faq.octoprint.org/mjpg-streamer-config for available options
# Defaults to a resolution of 640x480 px and a framerate of 10 fps
camera_usb_options= "-r 640x480 -f 2 -y"
But I needed
camera_usb_options="-r 640x480 -f 2 -y"
see it? the damn space prior to the options killed it
