Can't run PSU form command line (ssh), get an error
Following this recommendations https://github.com/jneilliii/OctoPrint-PrintScheduler/wiki/Helpful-System-Commands, am trying to run this from an ssh as a test
"octoprint@Climber7:/root$ /home/octoprint/python_venvs/octoprint1/bin/octoprint plugins psucontrol:on"
PSU is configured (via system command gpio write) and runs well from the octoprint web.
But when I try running the above form ssh I get this (no matter from what user I run it).
Initializing settings & plugin subsystem...
Error loading plugin smartfilamentsensor
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint/plugin/core.py", line 1264, in _import_plugin
module = _load_module(module_name, spec)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint/plugin/core.py", line 69, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 238, in load_module
return load_package(name, filename)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 212, in load_package
return _load(spec)
File "<frozen importlib._bootstrap>", line 696, in _load
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_smart_filament_sensor/__init__.py", line 5, in <module>
import RPi.GPIO as GPIO
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/RPi/GPIO/__init__.py", line 23, in <module>
from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
Initializing GcodePositionProcessor V1.0.1 - Copyright (C) 2019 Brad Hochgesang...Python 3+ Detected...complete
2021-09-04 22:43:06,899 - octolapse.__init__ - INFO - Release mode detected.
Error loading plugin OctoBuddy
return _load(spec)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_OctoBuddy/__init__.py", line 5, in <module>
Error loading plugin filamentsensorsimplified
return _load(spec)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_filamentsensorsimplified/__init__.py", line 8, in <module>
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connection.py", line 170, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/util/connection.py", line 96, in create_connection
raise err
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connectionpool.py", line 706, in urlopen
chunked=chunked,
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connection.py", line 234, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/lib/python3.7/http/client.py", line 1260, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.7/http/client.py", line 1306, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.7/http/client.py", line 1255, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.7/http/client.py", line 1030, in _send_output
self.send(msg)
File "/usr/lib/python3.7/http/client.py", line 970, in send
self.connect()
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connection.py", line 200, in connect
conn = self._new_conn()
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connection.py", line 182, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f6bc51a90>: Failed to establish a new connection: [Errno 111] Connection refused
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/connectionpool.py", line 756, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/urllib3/util/retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='127.0.0.1', port=5000): Max retries exceeded with url: /api/plugin/psucontrol?command=turnPSUOn (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f6bc51a90>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/home/octoprint/python_venvs/octoprint1/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint/__init__.py", line 948, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/click/core.py", line 829, in __call__
return self.main(*args, **kwargs)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/click/core.py", line 782, in main
rv = self.invoke(ctx)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/click/core.py", line 1259, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/click/core.py", line 1066, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/click/core.py", line 610, in invoke
return callback(*args, **kwargs)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_psucontrol/cli.py", line 41, in turnPSUOn_command
r = _api_command('turnPSUOn', apikey, host, port, httpuser, httppass, https, prefix)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_psucontrol/cli.py", line 28, in _api_command
r = client.post_command("plugin/psucontrol", command)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_client/__init__.py", line 278, in post_command
return self.post_json(path, data, params=data, timeout=timeout)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_client/__init__.py", line 272, in post_json
return self.post(path, data, encoding="json", params=params, timeout=timeout)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_client/__init__.py", line 268, in post
"POST", path, data=data, encoding=encoding, params=params, timeout=timeout
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint_client/__init__.py", line 260, in request
response = s.send(request, timeout=timeout)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='127.0.0.1', port=5000): Max retries exceeded with url: /api/plugin/psucontrol?command=turnPSUOn (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f6bc51a90>: Failed to establish a new connection: [Errno 111] Connection refused'))
Error in atexit._run_exitfuncs:
File "/usr/lib/python3.7/logging/__init__.py", line 2039, in shutdown
h.close()
File "/home/octoprint/python_venvs/octoprint1/lib/python3.7/site-packages/octoprint/logging/handlers.py", line 31, in close
self._executor.shutdown(wait=True)
AttributeError: 'OctolapseConsoleHandler' object has no attribute '_executor'
