PSUControl automation stopped working
I've been using the OctoPrint-PSUControl plugin: https://github.com/kantlivelong/OctoPrint-PSUControl
To control the power of my printer using terminal commands hooked into my Ikea Trådfri outlet. I even wrote a guide on it: PSU control with Ikea Trådfri and no additional HW
While the PSUControl button still works the automatic shutdown after a print has finished has stopped working.
I'm guessing it's sensing some sort of command being sent and therefore staying awake.
I went through the output in the terminal tab and added the only other GCODE than temperature report M105 that I could find: M117 Set LCD Message to the list of ignored commands but to no avail.
Is there any way to check / monitor what's keeping the PSUControl alive except for the terminal output?
EDIT:
Additional info: I think the issue coincided with me installing OctoDash which requires the following plugins:
