Slicer (name, version, operating system)
PursaSlicer 2.0.0 Linux Mint 19.2 64
Sending gcode the temp changes
Exported the gcode
Logs (octoprint.log, serial.log or output on terminal tab, ...)
Recv: echo: External Reset
Send: N0 M110 N0125
Recv: Marlin 1.0.0
Recv: echo: Last Updated: Sep 3 2018 19:03:20 | Author: (Ender-3 Pro)
Recv: Compiled: Sep 3 2018
Recv: echo: Free Memory: 9679 PlannerBufferBytes: 1232
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo:SD init fail
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Send: N0 M110 N0125
Exec(GCodeSystemCommands): OCTO9
Return(GCodeSystemCommands): ok
Recv: ok
Send: N1 M115*39
Recv: ok
Send: M504
Recv: ok
Send: M501
Recv: ok
Example GCODE file
From octoprint:
"; generated by PrusaSlicer 2.0.0+linux64 on 2019-06-27 at 18:08:38
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.42mm
M73 P0 R6
M73 Q0 S6
M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm/sec
M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X10.00 Y10.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
G21; set mm units
G28 ;home all axis
M190 S60 ; set and wait for bed temp to be reached
M104 S190 ; set extruder temp and start heating
G28 ; Home all axes
M104 S190 ;
M109 S190; wait for extruder temp to be reached"
From slic3r
"; generated by PrusaSlicer 2.0.0+linux64 on 2019-06-27 at 18:41:53
M73 P0 R6
M73 Q0 S6
M107
G21; set mm units
G28 ;home all axis
M104 S210 ; set extruder temp and start heating
G28 ; Home all axes
M104 S210 ;
M109 S210; wait for extruder temp to be reached"
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware...)
Ocotprint Version 1.3.11, octopi latest, Ender 3 pro, stock fw
Nothing is changed between sending the gcode to octoprint and exporting it.
I only noticed since the filament wasn't sticking and the temp was down to 190 instead of 210.
