I can't login to RPi via PuTTY terminal session. I have two PCs to work with, neither can get me in via PuTTY.
login as: pi
pi@192.168.86.87's password:
Access denied
login as: pi
pi@octopi.local's password:
Access denied
I just purchased RPi 3 B+ and did a fresh image on a new Sandisk 32GB micro SD card. Everything else works. I can print using Octoprint via web browser over WiFi, I can access and login to pi@octopi via direct keyboard/monitor interface.
I followed Joe Mike Terranella's excellent YouTube tutorial series to image and configure.
Verified samba/smb.conf by doing
sudo testparm /etc/samba/smb.conf:
I would provide results, but I can't copy/paste since I can't get in via PuTTY.
octoprint.log (154.7 KB)
Pi: Raspberry Pi 3 Model B Plus Rev 1.3
Octopi 0.17.0
Octoprint 1.3.12
Printer: Alunar M505 with Anet V 1.0 board
Win 10
WiFi Router: Google Mesh - This is a relatively new mesh system. I was previously using a more conventional WiFi router. PuTTY SSH worked on my older RPi 3 B using the older router, maybe something with the Google router is blocking access?
I appreciate any help here, I've been reading forums for days now and I can't seem to find an answer, or even a troubleshooting path to follow.
