Complete Logs
Successfully installed pip-20.2.4
(venv) pi@raspberrypi:~/OctoPrint $ pip install octoprint
DEPRECATION: Python 3.5 reached the end of its life on September 13th, 2020. P lease upgrade your Python as Python 3.5 is no longer maintained. pip 21.0 will drop support for Python 3.5 in January 2021. pip 21.0 will remove support for this functionality.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
ERROR: Could not find a version that satisfies the requirement octoprint (from versions: none)
ERROR: No matching distribution found for octoprint
