It's usually a good idea to let OctoPrint manage the pip version. That's a fairly dramatic leap, if you ask me. What's also odd is that the before version doesn't report itself surrounded by single quotes and the after version does.
| pip: 9.0.3 # before
| pip: '18.1' # after
Not sure what you mean by this, to be honest.
2018-12-29 20:58:52,771 - octoprint.plugin.core - ERROR - Error fetching plugins from entry points
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 662, in _find_plugins
ignore_uninstalled=ignore_uninstalled)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 760, in _find_plugins_from_entry_points
for entry_point in wrapped(working_set.iter_entry_points(group=group, name=None)):
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 752, in wrapped
for entry in gen:
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 726, in iter_entry_points
entries = dist.get_entry_map(group)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2639, in get_entry_map
self._get_metadata('entry_points.txt'), self
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources/__init__.py", line 2373, in parse_map
raise ValueError("Entry points must be listed in groups")
ValueError: Entry points must be listed in groups
2018-12-29 20:59:00,827 - octoprint.plugins.pluginmanager - ERROR - Installing the plugin from https://framagit.org/razer/Octoprint_ABL_Expert/-/archive/master/Octoprint_ABL_Expert-master.zip failed, could not parse output from pip. See plugin_pluginmanager_console.log for generated output
2018-12-29 22:54:31,324 - octoprint.plugins.softwareupdate - WARNING - Cannot perform update for octoprint, update type is not fully configured
Try running in Safe Mode, check the octoprint.log for any errors. If it's clean after the last boot, then try the upgrade again by visiting the Settings page for that.
