failed to install python3-dev
I log into my Pi via SSH
I prefer to use the screen command
Then
curl -L https://get.octoprint.org/py3/upgrade.py --output upgrade.py
python3 upgrade.py
ok so far
Checking package list for python3-dev
Installing python3-dev...
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
ERROR: failed to install python3-dev
Please try manually
Cleaning up...
Fatal error: Exiting
So i do sudo dpkg --configure -a
It asking me something a new version of config file of openssh. because i dont use it i choose the maintainer's version.
Errors were encountered while processing:
libmagic1:armhf
file
Then i did sudo dpkg --configure -a again
pi@octopi:~ $ sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of libmagic1:armhf:
libmagic1:armhf depends on libmagic-mgc (= 1:5.35-4+deb10u2); however:
Package libmagic-mgc is not installed.
dpkg: error processing package libmagic1:armhf (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of file:
file depends on libmagic1 (= 1:5.35-4+deb10u2); however:
Package libmagic1:armhf is not configured yet.
dpkg: error processing package file (--configure):
libmagic1:armhf
file
Then again
python3 upgrade.py
Then i got a lot of Cache entry deserialization failed, entry ignored messages.
last line is Installing collected packages and then the connection get lost.
no
donno
octoprint-systeminfo-20211021125017.zip (3.5 KB)
OctoPrint Version 1.7.0
OctoPi Version 0.17.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Win10
Firefox 93.0
Marlin
