Qidi x-one2 setup
I would like to connect my Octoprint Raspberry Pi 3 B to my Qidi x-one2 printer.
I am hoping someone with experience ( @FrankR ) can help guide me and I won't have to reinvent the wheel (so to speak). I am a visual learner so pictures would be amazing.Thanks for any wisdom y'all can share!
I plan to hook up with octopi-stretch-lite-0.15.1 with the patch described in this thread specifically for the Qidi X-one2.
  1. I burnt the image onto a Micro SD card using Etcher
  2. I used Notepad++ to change the SSID name and Password
  3. I put the SD card into the Pi 3 B
  4. I hooked the Pi to the USB port on the Qidi printer (located right next to the SD card slot).
  5. I hooked the Pi up with a wifi dongle.
  6. I turned on the printer.
  7. I powered on the Pi.
I am not seeing the Octopi connecting to Wifi on my router. I am guessing this is a simple error I made in configuring the Wifi on the image. After I connect, is that when I will be able to implement the patch, or do I do that when I'm burning the image to the Pi?
I don't know what diagnostic info I can post w/o being able to connect to the Pi, but I will update more as I make progress. Any direction or ideas are appreciated.
-Mike
Are you sure about that? Per this review, it has USB connectivity and it should have come with the cable.
I found it, hiding in plain sight. Can't believe I didn't notice it until now >.< hopefully the rest of the setup will be smooth sailing.
I am all set up and running. I couldn't figure out how to delete this thread, but I feel it doesn't really add much to the forum. If an admin want's to delete I say go for it, otherwise you can leave it up and I can try to help out the next person who is struggling with this particular printer :slight_smile:
can you explain how you solved it?
I have the same problem
Tnks
I got pretty frustrated with trying to set up my Qidi X-One2 with Octopi. There are several versions of the Qidi X-One2 printer. The blue version and the red and blue version. I happened to have the red&blue with just the USB2-Type A Storage Slot.
I have also found they have three versions of motherboards as follows: (Current Motherboard) V4.8 with the USB Memory Stick - No UART pins. (Small Motherboard) V5.3 with the USB Memory Stick and UART pins. (Original Motherboard) V7.4 with the SD Card Reader with USB2-Type B port.
So I guessing you have either V7.4 using the USB2-Type B port or the V5.3 with the UART pins. Took a few days to see everyone posting that they could use the Qidi X-One2 with Octopi and that some people are frustrated that they cant find the UART pins or the board is just a blank on that part of the board. The V5.3 board is on Ebay from the manufacturer for those that are wanting to connect it their network. It is a pity that the WiFi pin headers are non functional.
How do you upload images once you put another SD card and the screen is not showing
Images are uploaded to the Raspberry P, and stored in Octoprint. Is your Qidi X One 2 connected to the Raspberry PI via the UART USB cable?
