Hello,
The "upload to SD" button remains light blue. The connection works but cannot display the files on the printer card. Printing is only possible from files uploaded to the raspberry
M503 : Unknown command:M503
I used other cards, lighter gcode files, disabled "Enable automatic firmware detection" in "Protocol & firmware", enabled "Select SD files by relative path" ... and the card of another printer is appeared! (saved as non-default printer, on, cable connected but not active in octopi.local)
I tried with another raspberry wtih a brand nex octopi install. Same result.
Complete Logs
serial.log (12.1 KB) octoprint.log (55.4 KB)
console.log (952 Bytes)
OctoPrint : 1.4.0
QQS Pro - stock firmware - firefox 79.0 - Windows 10 100
