I don't use a Raspberry Pi to run OctoPrint, as i had an extra banged up 2 in 1 laptop that i Installed Ubuntu onto. I just wanted to know if there was a plugin for Octoprint to detect a filament runout sensor attached to the printer, and not GPIO pins on the device running OctoPrint. I don't have GPIO on the laptop.
Thinking about ordering an FT232HQ based USB to GPIO board to get this to work
Complete Logs
Ender 3 pro with 4.2.2 board, most recent marlin bugfix, firefox on ubuntu, not a raspberry pi based setup, but is straight linux based setup on Ubuntu 20.04
If the firmware supports action commands, OctoPrint has built in support for it. In Marlin, you can enable HOST_ACTION_COMMANDS and HOST_PROMPT_SUPPORT in Configuration_adv.h, then the printer will give the details to OctoPrint.
Thank you. I will give this a try after my current print is done. I ordered one of the FT232HQ boards anyway. It'll be fun to play with GPIO, and ill need more pins for the enclosure i'm working on.
Oh, it's not that old, haha. It's only about 4 years old. It's a Dell 2 in 1 touchscreen. The digitizer is cracked, so the touch doesn't work. 2 columns down the keyboard don't work. The battery doesn't charge, and it's not the power supply, it works fine on other laptops. But, it folds flat, keyboard at the back, and mounts nicely to the wall to keep the dashboard up to have a look at where the prints are at. It's a quad core i5 with 4 Gb of ram, 11 inch screen, and a real 2.5inch ssd drive in it.
No serial port. The FT232HQ USB adaptor was 20 bucks on amazon. It'll give me a few gpio outputs easily.
The FT232H/HQ chips are a USB to serial/parallel adaptor really. Will handle GPIO, I2C, SPI, JTAG, and many others. It will give me 12 GPIO ports to play around with.
I case you haven't heard of it here's the data sheet for the 232h, but the HQ is the same.
it has 12 GPIO pins that it is capable of using through the usb to serial capabilities. I have still been working on this when i have time. Not really getting to far.
it works just like a normal GPIO interface on the Rpi, i just wanted to see if i could make plugin that uses it, instead on the Rpi.gpio thats depreciated.
