I am confused about rpi4 support and performance, I would like to know if a raspberry pi 4 4GB can handle two printers and two webcams
Did some research on rpi 4 performance
Can: yes
Should: no
It is not officially supported, so you will not get a lot of help if you run into trouble.
Personally I'm using the PiA+, 1 on each of my printers. Monoprice Mini v.1 and Creality Ender3 Pro.
My primary OS on my PC is Ubuntu 19.04. I am running Cura 4.3 works great. The filename of each sliced file has a prefix to either printer. Setting up a set of folders for each one must be disciplined. I like it. I upload the gcode file into either pi. One has 32gb msd, the other has a 16gb msd. I suppose space for gcode files may eventually be an issue. I keep my files on a 750gb external USB3 Drive.
