Hello, I'm looking for a solution to an all around video monitor for my 4 printers. Are there any "plug and play" options available that connect to Octoprint? I need something that's quick to set up since I move them around a lot and doesn't require me to buy and set up 4 different cameras.
If you are using OctoPrint, you can just use a standard USB webCam... Once it is setup, you just need to plug it in. If you move your printer, I would expect you would be moving the OctoPrint device which you could just bring the Camera with as well. My cameras are physically attached to the printers. If I pick up a printer and move it to a new location the camera comes with it. Worst case, I have to unplug it, but I can just plug it back into the USB port and its ready to go.. No new setup is required. I just power it up in the new location.
Maybe there is more to this than I am understanding from your question.
