2018-08-20 17:42:47,644 - octoprint.startup - INFO - ******************************************************************************
2018-08-20 17:42:47,645 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-08-20 17:42:47,645 - octoprint.startup - INFO - ******************************************************************************
2018-08-20 17:42:47,698 - octoprint.plugin.core - INFO - Loading plugins from c:\python27\lib\site-packages\octoprint\plugins, C:\Users\Xeon\AppData\Roaming\OctoPrint\plugins and installed plugin packages...
2018-08-20 17:42:49,931 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-08-20 17:42:50,115 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-08-20 17:42:50,118 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-08-20 17:42:50,200 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-08-20 17:42:50,421 - octoprint.server - INFO - Intermediary server started
2018-08-20 17:42:50,423 - octoprint.plugin.core - INFO - Loading plugins from c:\python27\lib\site-packages\octoprint\plugins, C:\Users\Xeon\AppData\Roaming\OctoPrint\plugins and installed plugin packages...
2018-08-20 17:42:50,427 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-08-20 17:42:50,536 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-08-20 17:42:50,538 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
2018-08-20 17:42:50,566 - octoprint.filemanager.storage - INFO - Initializing the file metadata for C:\Users\Xeon\AppData\Roaming\OctoPrint\uploads...
2018-08-20 17:42:50,568 - octoprint.filemanager.storage - INFO - ... file metadata for C:\Users\Xeon\AppData\Roaming\OctoPrint\uploads initialized successfully.
2018-08-20 17:42:53,115 - octoprint.util.pip - INFO - Using "c:\python27\python.exe -m pip" as command to invoke pip
2018-08-20 17:42:53,767 - octoprint.util.pip - INFO - Version of pip is 18.0
2018-08-20 17:42:53,767 - octoprint.util.pip - INFO - pip installs to c:\python27\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> no
2018-08-20 17:42:53,767 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-08-20 17:42:53,769 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-08-20 17:42:53,789 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = c:\python27\lib\site-packages\octoprint\plugins\action_command_prompt
| Announcement Plugin (bundled) = c:\python27\lib\site-packages\octoprint\plugins\announcements
| Core Wizard (bundled) = c:\python27\lib\site-packages\octoprint\plugins\corewizard
| CuraEngine (<= 15.04) (bundled) = c:\python27\lib\site-packages\octoprint\plugins\cura
| Discovery (bundled) = c:\python27\lib\site-packages\octoprint\plugins\discovery
| Logging (bundled) = c:\python27\lib\site-packages\octoprint\plugins\logging
| Plugin Manager (bundled) = c:\python27\lib\site-packages\octoprint\plugins\pluginmanager
| Printer Safety Check (bundled) = c:\python27\lib\site-packages\octoprint\plugins\printer_safety_check
| Software Update (bundled) = c:\python27\lib\site-packages\octoprint\plugins\softwareupdate
| Virtual Printer (bundled) = c:\python27\lib\site-packages\octoprint\plugins\virtual_printer
2018-08-20 17:42:53,799 - octoprint.environment - INFO - Detected environment is Python 2.7.14 under Windows (win32). Details:
| hardware:
| cores: 24
| freq: 2934.0
| ram: 3211968512
| os:
| platform: win32
| python:
| pip: '18.0'
| version: 2.7.14
2018-08-20 17:42:53,803 - octoprint.server - INFO - Reset webasset folder C:\Users\Xeon\AppData\Roaming\OctoPrint\generated\webassets...
2018-08-20 17:42:53,803 - octoprint.server - INFO - Reset webasset folder C:\Users\Xeon\AppData\Roaming\OctoPrint\generated.webassets-cache...
2018-08-20 17:42:53,881 - octoprint.server - INFO - Shutting down intermediary server...
2018-08-20 17:42:53,921 - octoprint.server - INFO - Intermediary server shut down
2018-08-20 17:42:53,924 - octoprint.events - INFO - Processing startup event, this is our first event
2018-08-20 17:42:53,924 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-08-20 17:42:53,926 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-08-20 17:42:53,927 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-08-20 17:42:53,930 - octoprint.plugins.cura - INFO - Path to CuraEngine has not been configured or does not exist (currently set to None), Cura will not be selectable for slicing
2018-08-20 17:42:53,933 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on Xeon-PC for SSDP
2018-08-20 17:42:53,953 - octoprint.server - INFO - Listening on http://[::]:5000
2018-08-20 17:42:54,776 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2018-08-20 17:42:54,825 - octoprint.plugins.announcements - INFO - Loaded channel _important from Important OctoPrint Announcements in 0.85s
2018-08-20 17:42:55,382 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2018-08-20 17:42:55,401 - octoprint.util.pip - INFO - Using "c:\python27\python.exe -m pip" as command to invoke pip
2018-08-20 17:42:55,512 - octoprint.plugins.announcements - INFO - Loaded channel _releases from OctoPrint Release Announcements in 0.59s
2018-08-20 17:42:56,114 - octoprint.plugins.announcements - INFO - Loaded channel _blog from OctoBlog in 0.59s
2018-08-20 17:42:56,617 - octoprint.util.pip - INFO - pip installs to c:\python27\Lib\site-packages\ (writable -> yes), --user flag needed -> no, virtual env -> no
2018-08-20 17:42:56,617 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-08-20 17:42:56,622 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-08-20 17:42:56,648 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from OctoPrint Plugin Repository in 0.52s
2018-08-20 17:42:57,585 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from OctoPi Announcements in 0.91s
2018-08-20 17:44:08,308 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-08-20 17:49:23,525 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2018-08-20 17:51:14,711 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-08-20 17:56:40,358 - tornado.access - WARNING - 401 POST /api/login (::1) 22.00ms
2018-08-20 17:57:50,201 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-08-20 18:02:38,003 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
2018-08-20 18:02:40,055 - octoprint.server.util.sockjs - INFO - New connection from client: ::1
2018-08-20 18:12:50,201 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-08-20 18:13:37,647 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-08-20 18:13:37,888 - octoprint.util.comm - INFO - Could not enter programming mode on COM1: 'Failed to open serial port'
2018-08-20 18:13:43,423 - octoprint.util.comm - INFO - Could not enter programming mode on COM4: 'Timeout'
2018-08-20 18:13:43,538 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2018-08-20 18:13:58,934 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-08-20 18:13:58,934 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2018-08-20 18:13:59,963 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:09,983 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:11,013 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:12,048 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:13,085 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:14,124 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:15,124 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:16,125 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:17,153 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:18,155 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:19,157 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:20,183 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:21,207 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:22,232 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:23,256 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:24,282 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:25,355 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:26,427 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:27,502 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:28,573 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:29,648 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:30,726 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:31,799 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:32,884 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:33,953 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:35,039 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:36,223 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:37,405 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:38,588 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:39,769 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:40,953 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:42,233 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:43,512 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:44,789 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:46,075 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:14:47,345 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Error: No more baudrates to test, and no suitable baudrate found."
2018-08-20 18:14:47,451 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more baudrates to test, and no suitable baudrate found." to "Offline (Error: No more baudrates to test, and no suitable baudrate found.)"
2018-08-20 18:19:38,201 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-08-20 18:19:38,211 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-08-20 18:19:38,211 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:20:18,322 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2018-08-20 18:21:43,809 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-08-20 18:21:43,809 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-08-20 18:21:43,809 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:22:23,918 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2018-08-20 18:25:35,660 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-08-20 18:25:35,660 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-08-20 18:25:35,660 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:26:15,769 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2018-08-20 18:26:38,170 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-08-20 18:26:38,180 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-08-20 18:26:38,180 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:27:18,289 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2018-08-20 18:27:50,210 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-08-20 18:29:22,075 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-08-20 18:29:22,085 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-08-20 18:29:22,085 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-08-20 18:30:02,196 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2018-08-20 18:31:13,278 - octoprint.server.util.sockjs - INFO - Client connection closed: ::1
