I am having problems with printer disconnect. Disconnect happens randomly every time.
Printer FlSun Q5/
I used several USB wires. Several different power supplies, eventually settled on the power supply from the PC.
I use OrangePi PC as a control board. The connection speed is 115200, at 250000 the problem also persists. OrangePi itself is connected via LAN.
Firmware Marlin 2.0. Printer Board, MKS Robin Nano.
File "/home/octoprint/OctoPrint/venv/local/lib/python2.7/site-packages/OctoPrint-1.4.0-py2.7.egg/octoprint/util/comm.py", line 2823, in _readline
ret = self._serial.readline()
File "/home/octoprint/OctoPrint/venv/local/lib/python2.7/site-packages/OctoPrint-1.4.0-py2.7.egg/octoprint/util/comm.py", line 4968, in readline
c = self.read(1)
File "/home/octoprint/OctoPrint/venv/local/lib/python2.7/site-packages/pyserial-3.4-py2.7.egg/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2020-04-19 12:55:47,525 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2020-04-19 12:55:47,542 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2823)"
2020-04-19 12:55:47,553 - octoprint.filemanager.analysis - INFO - Starting analysis of local:LED_LAMP/D_Ball.gcode
2020-04-19 12:55:47,558 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/octoprint/OctoPrint/venv/bin/python -m octoprint analysis gcode --speed-x=7200 --speed-y=7200 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/octoprint/.octoprint/uploads/LED_LAMP/D_Ball.gcode
2020-04-19 12:55:48,158 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': u'local', u'reason': u'error', u'commerror_text': u"SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2823", 'file': '8653834062b567ed6a8b77c026ef8b0f7e50e098', u'elapsed': 4155}
2020-04-19 12:56:17,335 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
