When using Octoprint (1.7.3) running OctoPi (0.18.0) on a Pi3B+ (Python 3.7.3), I get random movements to the same locations during the print, where the print-head pauses for 1-2 seconds (oozing out some material) before continuing print. It seems to do this each layer depending on the shape.
I ran in SAFE mode.
Then ran normally. Problem occurred again.
Then I disabled plugins some plugins which people had mentioned can cause issues with the print.
If the printer is connected to the computer through USB (not using RPi3+) the prints are do not have this issue.
Only occurs when running OctoPi/Octolapse in normal mode with plugins enabled.
Yes
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 connectivity.connection_check: 1.1.1.1:53 connectivity.connection_ok: True connectivity.enabled: True connectivity.online: True connectivity.resolution_check: octoprint.org connectivity.resolution_ok: True env.hardware.cores: 4 env.hardware.freq: 1200.0 env.hardware.ram: 914001920 env.os.bits: 32 env.os.id: linux env.os.platform: linux env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2 env.plugins.pi_support.octopi_version: 0.18.0 env.plugins.pi_support.octopiuptodate_build: 0.18.0-1.7.3-20220323100241 env.plugins.pi_support.throttle_state: 0x0 env.python.pip: 20.3.3 env.python.version: 3.7.3 env.python.virtualenv: True octoprint.safe_mode: False octoprint.version: 1.7.3 systeminfo.generator: zipapi System info bundle (Safe mode) [octoprint-logs (safe mode).zip|attachment](upload://AjLzi0q6EnrWf87LWeDUEfzPTMo.zip) (404.8 KB)System info bundle (Normal mode: Plugins enabled)
octoprint-logs (Normal mode).zip (446.8 KB)
Plugins installed
Bed Leveling Wizard
BetterHeaterTimeout
Camera Settings (0.3.2)
Cancel Objects (0.4.7)
Cura Thumbnails (1.0.2)
Dashboard (1.19.8)
Detailed Progress (0.2.7) ---- Disabled
DisplayLayerProgress Plugin (1.28.0) ---- Disabled
DisplayProgress (0.1.3) ---- Disabled
Exclude Region (0.3.0)
GCode Viewer
Marlin EEPROM Editor (3.2.0)
OctoDash Companion (0.0.7)
OctoEverywhere! (1.6.6)
Octolapse (0.4.1)
PreHeat Button (0.8.0)
PrettyGCode (1.2.4)
PrintTimeGenius Plugin (2.2.8)
Resource Monitor (0.3.6)
SimpleEmergencyStop (1.0.5)
Slic3r (1.3.0)
Slicer Thumbnails (1.0.0)
Spoolmanager Plugin (1.7.0)
Filament Manager (1.9.1)
There are other standard plugins that installed with OctoPi/Octoprint.
OctoPrint version 1.7.3, OctoPi version 0.18.0, Bukito, Marlin 1.0, Firefox, Win10,
The printer is similar to a Ender 2 (i think), or Prusa mini.
It has a custom Azteeg V2 board (8-bit I believe)
The Marlin software is Version 1.0. I am uncertain if it can even be upgraded to a later version.
At the moment I do not have a copy of the firmware to modify and test.
When printing from the computer instead, this print move does not occur. I'm using Repetier Host V2.2.2 for the computer driven control with a Slic3r for slicing.
Slic3r is used for slicing the files which are then saved and uploaded through Octoprint interface if I print with the RPi3 instead.
I have Cura 4.3 and Prusa-Slicer 2.4.1 but I have not set them up for this printer.
This is an copy of the Terminal log when the move/pause occurs (Normal mode)
Send: N1043 G1 X68.632 Y72.411 E4.3335688
Recv: ok
Send: N1044 G1 F8160.000110
Recv: ok
Send: N1045 G1 X68.632 Y71.984 E4.1547388
Recv: ok
Send: N1046 G1 F8160.000108
Recv: ok
Send: N1047 G1 X68.878 Y71.984 E4.0514886
Recv: ok
Send: N1048 G1 F8160.00098
Recv: ok
Send: N1049 G1 X68.632 Y72.411 E3.8449892
Recv: ok
Send: N1050 G1 E1.33356 F3600.0000043
Recv: ok
Send: N1051 G92 E0114
Recv: ok
Send: N1052 G1 X63.964 Y72.516 F10200.00093
Recv: ok
Send: N1053 G1 E2.80000 F3600.0000035
Recv: ok
Send: N1054 G1 F4200.000102
Recv: ok
Send: N1055 G1 X63.964 Y71.984 E2.8249190
Recv: ok
Send: N1056 G1 X63.452 Y71.984 E2.8488883
Recv: ok
Send: N1057 G1 X63.759 Y72.516 E2.8776581
Recv: ok
Send: N1058 G1 X63.964 Y72.516 E2.8872484
Recv: ok
Send: N1059 G1 X61.108 Y71.410 F10200.00082
Recv: ok
Send: N1060 G1 F4200.00097
Recv: ok
Send: N1061 G1 X61.108 Y69.690 E2.9678290
Recv: ok
Send: N1062 G1 X60.268 Y69.690 E3.0071795
Recv: ok
