Random pausing just my luck
random pausing
i wouldnt know where to start
no
havent tried
octoprint-systeminfo-20230416201254.zip (67.5 KB)
hi i had a couple of random pauses today the first i resumed and it caried on no problem but the second when i resumed it it just stayed where it was and extruded silly thing just my luck.
Version 1.8.7, , ender 3, firmware, opera, octoprint on pi 4 browser windows 11,
thanks
martin
One of the first things to try.
You may turn off the Crealty Cloud:
2023-04-16 18:42:50,685 - octoprint.util.comm - INFO - Pausing/resuming job on behalf of plugin crealitycloud
Besides:
Octoapp complains to get no camera image:
2023-04-16 18:14:55,895 - octoprint.plugins.octoapp - WARNING - Failed to get webcam snapshot Invalid URL '': No scheme supplied. Perhaps you meant https://?
Filamentreloaded complains no filament:
2023-04-16 18:39:16,759 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 16
2023-04-16 18:39:17,018 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 16
2023-04-16 18:39:17,279 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 16
2023-04-16 18:39:17,538 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 16
2023-04-16 18:39:17,798 - octoprint.plugins.filamentreload - INFO - The value of the pin is 0. No filament = False input = 16
thanks ive removed the Crealty Cloud thing and the coto app thing
and the Filamentreloaded thing is working fine i think it would change to -The value of the pin is 1. No filament = true, i think as the icon on the top bar is green when the filament is there and orange when its runout.
thanks
martin
its doing it again.
octoprint-systeminfo-20230418181119.zip (60.0 KB)
any help would be great .
thanks
martin
If there is still filament, you may check the cabling of the filament sensor:
2023-04-18 18:06:22,638 - octoprint.plugins.filamentreload - INFO - Out of filament!
2023-04-18 18:06:22,647 - octoprint.plugins.filamentreload - INFO - Pausing print.
2023-04-18 18:06:22,649 - octoprint.util.comm - INFO - Pausing/resuming job on behalf of plugin filamentreload
2023-04-18 18:06:22,649 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2023-04-18 18:06:26,794 - octoprint.printer.standard.job - INFO - Print job paused - origin: local, path: CE3E3_cam_zada.gcode, owner: admin, user: None
2023-04-18 18:06:26,799 - octoprint.plugins.filamentreload - INFO - PrintPaused: Disabling filament sensor.
2023-04-18 18:06:26,984 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
hi
thanks just checked wires and seem fine if i unplug the sensor i get
2023-04-18 18:51:57,811 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = True input = 16
2023-04-18 18:51:58,079 - octoprint.plugins.filamentreload - INFO - The value of the pin is 1. No filament = True input = 16
the thing is when i pressed resume it stopped responding.
hi me again any idea what this lot means ,
023-04-18 18:09:49,055 - octoprint.plugins.DisplayLayerProgress - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-04-18 18:09:49,056 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin DisplayLayerProgress is DISABLED
2023-04-18 18:09:49,079 - octoprint.plugins.filamentreload - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-04-18 18:09:49,080 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin filamentreload is DISABLED
2023-04-18 18:09:49,086 - octoprint.plugins.printhistory - WARNING - The Blueprint of this plugin is relying on the default implementation of is_blueprint_csrf_protected (newly added in OctoPrint 1.8.3), which in a future version will be switched from False to True for security reasons. Plugin authors should ensure they explicitly declare the CSRF protection status in their BlueprintPlugin mixin implementation. Recommendation is to enable CSRF protection and exempt views that must not use it with the octoprint.plugin.BlueprintPlugin.csrf_exempt decorator.
2023-04-18 18:09:49,086 - octoprint.server - WARNING - CSRF Protection for Blueprint of plugin printhistory is DISABLED
2023-04-18 18:09:49,850 - octoprint.server - INFO - Shutting down intermediary server...
2023-04-18 18:09:49,931 - octoprint.server - INFO - Intermediary server shut down
thank you
martin
Nothing to worry about.
Those are infos for plugin devs.
oh ok
think I'm going to disable filamentreloaded for now .
thanks for the help its much appreciated
martin
here we go again ,
Creality printers are infamous for being susceptible to EMI and infamous for generating EMI. I think you may be suffering from this. Search this forum for "Creality EMI" and you will find multiple topics with symptoms and solutions.
A better USB cable and/or re-routing the printer's internal cables may help minimize the effects.
thanks i'll do some reading .
martin
